Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: Setting up a FSV2 from scratch...
  1. #21
    Senior Member jeff keyuk's Avatar
    Jun 2008
    Hey Joe! keep up the good work! spring is around the corner,Looking forward to get back working on the car.
  2. #22
    swingtan
    Guest
    A quick tip on internal memory vs the SD card.
    Internal memory is about 2MB, which will give around 30 min worth of logging on an E38, less if logging a TCM as well.
    Approximate tune file sizes (ctz) are as follows...
    • LS1B - 0.44 MB
    • E40 - 0.91 MB
    • E38 - 1.7 MB
    • E39 - 2.7 MB
    • T42 - 0.44 MB
    • T43 - 1.56 MB
    Simon.
  3. #23
    Mar 2013
    I have been trying to get my v2 back up to date and I have downloaded the latest software and am trying to get the v.8 software up and running. After programing the pids in v.8 and saving I switched over to the tools section and selected the convesion as directed. What is this doing? It states no .ctd files were found and no files were converted. verifying .ctz files, no files were verified. What am I doing wrong?
  4. #24
    Quote Originally Posted by nicen_tech View Post
    First do this: click on the "..." button and browse to the folder where your .tun files are located.
  5. #25
    Mar 2013
    Thanks for the reply, thats what I am doing. I dont have the files saved in the V7.5 or V8 folders because when I go to save them they dont display available in the save as folder, I have them saved to a desktop folder. Could this be my problem? The files are saving as a .tun file and not a .ctd file. What is the difference between the .ctd, .ctz, and the .tun files?
  6. #26
    .tun = V7 tunetool old format
    .ctd = V8/V2 format, not used any more
    .ctz = V8/V2 format
    Move your .tun files from the desktop to My Documents\EFILive\V7.5\Bins (or similar for Win 7/8); note that this path is settable in scantool, goto Edit->Properties->Folders).
    From the V7 tunetool you can save a tune file as .ctz, go File->Save Tuning File As, and select .ctz as the type.
  7. #27
  8. #28
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Where can I find V7 Build 222 and V8 Build 215?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
  9. #29
    Quote Originally Posted by 67SS509 View Post
    In the RC1 thread?
  10. #30
    RC2 replaces those with 225 and 219 respectively.
  1. Replies: 4
    Last Post: April 9th, 2011, 06:53 AM
  2. Help setting up LC1
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 03:51 PM
  3. building LS from scratch, what ECU options, etc.
    By general23cmp in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 03:46 AM
  4. Changing usb cable on FSV2
    By AGRO in forum General
    Last Post: May 2nd, 2008, 01:09 PM
  5. Setting up PLX with V2
    By mtnman in forum FlashScan V2
    Last Post: February 8th, 2007, 07:20 AM
