Results 11 to 20 of 53
Thread: Update: May 25, 2013
    Read All Diagnostics
    the Freeze Frames are missing again, compare attached files...
    DTC_1547.txt: 2.7.41
    DTC_1558.txt: 2.7.42
    Also, in the saved file the monitors supported and monitor states being split into two groups is good...
    but when viewing the monitors on the V2 LCD is there a way of making it more compact (e.g. as in a previous version: ready, pending, n/a)...?
    2.7.42
    That's weird that the FF are missing again :( I'll check it out.
    The SRT results must show "Complete" for tests that are not supported (the "Not Supported" part is optional). That means the testing technician only has to see all tests showing as "Complete" regardless of whether they are supported or not. I guess CARB thought it was too complicated to get a testing technician to check whether a test is supported or not - sigh!!!
    No real way to display both values on one line - especially on AutoCal.
    But I would rather report it the compact way, I'll see if I can come up with something...
    Yes please.
    Sent.
    So the unsupported ones are always ready...
    so actually there are 4 states (of which one is not legal).
    Yes, the hard part is designing sutiable abbreviated display labels to fit the V2/AC LCD...
    [ e.g. RDY (ready/supported), PND (pending/supported), CMP (complete/unsupported), INC (incomplete/unsupported) ]
    But note: in the "Read All Diags" saved file, do leave them grouped separately, that has its own special value (when looking at C6001, C6002 in the tune file).
    Read CVN, Read All Diags:
    The CVN's are showing up as zeros, see attached.
Name:	CVN zeros 1.png
ID:	15191   Click image for larger version.
Name:	CVN zeros 2.png
    Also, for an unsupported OS, the CVN's part number reads as zero (but this doesn't really matter, unless it's a bug), see attached:
Name:	Other OS Zero PN for CVN.png
ID:	15194   Click image for larger version.
    Freeze Frame funny characters on V2 LCD (up-arrows, down-arrows), see attached:
ID:	15205   Click image for larger version.
ID:	15206   Click image for larger version.
ID:	15207   Click image for larger version.
ID:	15208   Click image for larger version.
    continuing...
ID:	15211   Click image for larger version.
ID:	15210   Click image for larger version.
  9. #19
    Also notice that in the DTC txt file the date is wrong (off by one month)... I did Set Now in HAPI.
  10. #20
    2.7.42
    Hi Joe,
    I can't make the CVN's show up as zero on my test LS1 here. Can you make them show zero on yours there, then save a trace file and send me the trace file, thanks?
  1. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  2. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  3. EFILive RC 4 (April 10, 2013)
    Last Post: April 22nd, 2013, 03:07 AM
  4. EFILive RC 2 (March 28, 2013)
    Last Post: April 9th, 2013, 12:24 AM
  5. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
