Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: EFILive V7.5 Hanging When Starting Up or Shutting Down
  1. #21
    Quote Originally Posted by mowton View Post
    Thanks Paul, quick question, is this FW considered an upgrade from the original build 235 FW. Would there be any reason we would have to go "back" to the original build 235 FW release? Also is there a plan to correct the issues with the 235 build to get it to operate with your latest FW above?
    Ed M
    The firmware I posted will work with versions of V7 from build 230 to build 237.
  2. #22
    Senior Member mowton's Avatar
    Oct 2008
    Thank you again Paul. Loaded firmware and am giving it a try.
    Ed M
    Update 10:25 PM est -- Loaded good and 7.5 (build 230) started up good, proper flash icons etc. Scan tool loaded as well. Will try out on vehicles tomorrow morning.
    Again, thank you Paul for your great support and fix. Now we both can enjoy the rest of the weekend (1 hr left for me )
  3. #23
    Oct 2008
    Tested today on 2 cars LS1 and E38 and all worked great. Tune, Scan and Custom OS worked as previously with build 230.
    Thanks again Paul and the team at EFI Live
    Ed M
  4. #24
    Feb 2008
    Is there anywhere to download an older version of V7 (V7.5.7 build 230)?
  5. #25
    Oct 2008
    Quote Originally Posted by Brads_rs View Post
    http://forum.efilive.com/showthread....se-Apr-23-2013
    You can find all version in this section
    PS -- April 23rd is our Anniversary
    Ed M
  6. #26
    No, we don't keep old versions on our servers. But I have re-uploaded build 230 here:
    http://download.efilive.com/Software....230_Setup.exe
  7. #27
    Oct 2008
    Ed M
    My bad, should have checked the link in this thread.....
    Sorry
    Ed M
  8. #28
    Feb 2008
    All is working well now. Went back to build 230 with the firmware that paul posted. So far so good
  9. #29
    Feb 2013
    Where are we with this Paul?
    Will 2.37 work with the New/Old Firmware correctly or is it better to Install 2.30 and the FW?
    (been away from the tuning side of things dealing with another mechanical failure, last time I used 2.35 it was hanging on shutdown so I had to do all my edits load the file into the V2 and program from there)
  10. #30
    Oct 2008
    Quote Originally Posted by IJ. View Post
    If you are having problems with the latest build (237/235) and firmware (7.45), your best resolution seems to be to load the 230 software and the latest (7.46) firmware. We did and all issues were resolved (with the exception of course what the new software alleviated) and we were back in business.
    Ed M
  1. Replies: 4
    Last Post: June 25th, 2010, 04:08 AM
  2. Need help with backfiring-shutting off
    By 67SS509 in forum Gen III V8 Specific
    Last Post: July 18th, 2009, 01:18 PM
  3. EFILIVE _TUNE.EXE HANGING...on startup
    By TFZ_Z06 in forum General
    Last Post: September 21st, 2008, 10:16 AM
  4. BB Logging keeps shutting off after a few seconds
    Last Post: May 8th, 2005, 04:19 AM
