Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 98
Thread: Update: June 06, 2013
  1. #81
    Jun 2013
    Well, It reads my Truck info and everything but the tune tool says the OS is not supported for it.
  2. #82
    Quote Originally Posted by neovitwin View Post
    In tunetool do Help->About, what build version does it say...?
  3. #83
    Jun 2013
    V7.5.7 (Build 235)
  4. #84
    Email the file to [email protected] and mention that V7 says OS not supported...
    also specify year/model/vehicle.
  5. #85
    Jun 2013
    I email them already after I saw you comment. How long do they usually take to answer back?
  6. #86
    Bump for 2013 Sonic OS #12655493...now I have one to tune!
  7. #87
    Junior Member jordylee18's Avatar
    Oct 2011
    Default Re: Update: June 06, 2013
    Does anyone else have problems with the yellow monitoring button in V7 scan tool? I can't monitor PIDs. I have to use the red log button in order to see data. I've had this problem for the last few updates. It hasn't worked for probably 6-8 months.
    Also, I guess the EDA PID list in V7 scan tool does not work??
  8. #88
    Quote Originally Posted by jordylee18 View Post
    Yellow button monitors data it does not record data. The charts show recorded data so you won't see any data on the charts while monitoring. The dash gauges should show data that is being monitored.
    Why do you assume the EDA data does not work? What problems do you have with it?
  9. #89
    Oct 2011
    I don't see any data at all on any gauges or charts. It seems like it starts to work for a split second then it pauses itself. When I click the paused button, it starts recording data.
    When I select the EDA PID list, and hit record, the data screen locks up and you have to hit stop. Then if I select my normal PID list it works fine. Maybe I'm missing something. I'm good at that.
  10. #90
    The yellow button is designed to do exactly that, start recording, but in pause mode so nothing gets recorded. In pause mde the data is displayed in the gauges and on the [Data (F9)] tab page but not in the charts.
    EDA is for Cummins controllers that have been programmed with EFILive's custom operating system (that transmit the EDA data) only. IT won't work on any other controller or operating system.
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: June 05, 2013
    Last Post: June 5th, 2013, 04:26 PM
  3. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  4. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  5. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
