Bumping this back up. Having this problem with a LBZ. Realized that I hadn't updated to newest builds, so I then updated v7 and v8 and firmware and bootloader. Has made no difference. When I go to flash, it says I need to license it. When I go to vin licenses list, it clearly lists the specific truck I am trying to flash as already licensed.... Don't want to have to purchase another license?
Please list your V7 and V8 software versions, along with your firmware and boot block versions too.
Cindy
Can you please also send me the following information:
- A license backup file from your V2, created using the version 8 software: EFILive Scan and Tune -> [F7: Licenses] -> [Backup]
- A *.htx trace file from the version 8 software process: EFILive Scan and Tune -> [F3: Tune] -> [F6: Cal-Flash] -> [Check License]
(the trace file should be saved in the folder: \My Documents\EFILive\V8\Trace)
Send files to paul@efilive.com
boot block 2.07.06
firmware 2.07.49
v8 2.2.234
v7- edit-7.5.7 build 242
