Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Thread: Update: Nov 21, 2013
    Default Update: Nov 21, 2013
    This update has been provided for customers that require the updated functionality listed in the "Updates" section below and for customers that require fixes to the known issues listed here.
    EFILive advises caution when using this update in a production environment.
    Download here:
    Updates:
    V7
    • Stopped V7 from attempting to create or update files in "Program Files" (i.e. PCMLocks.ini and *.lbu license backup files).
    • Added E86 (LML Duramax) calibration support.
    • Added E20 (Family-Z 4cyl Diesel) calibration support.
    • Added E83 (1.6L Turbo) calibration support.
    • Added Speed Limiters for E92 ECM.
    V8
    • Re-enabled "Created By" and "Modified By" fields which were incorrectly set to read-only.
    • Fixed "Modified By" date not being loaded correctly from tune files.
    • V8 now handles controllers with corrupted serial numbers (i.e. for E54(LB7) and E60(LLY) controllers) the same as V7. That means if V7 was used in the past to license a controller with a corrupted serial number, V8 will now respect that license when flashing that same controller.
    • Added Buttons on y-axis in charts to provide fast/easy access to auto-scale and hide/show data.
    • Added a prototype [F3: Data] view for V8 Scan Tool. The final data view layout/format will be different from simple layout released in this version.
    • Chart now receives focus when left-clicked while "Ctrl+F2 mouse disable" option is active. Which means you can use the arrow keys to move the chart inspector.
    • Activated [F4: DTC]->[F2: Controller] info option to allow controller info to be retrieved and displayed (DTC, Test Status, and Test Result options are not yet available). Not all controllers are support yet.
    • Fixed Access Violation error when attempting to change the VIN in a *.ctz file.
    • Chart playback now zooms to a 1:1 zoom while playing-back and reverts to the previous zoom level after playback stops.
    • Added a "Tip of the Day" display at start up.
    Firmware
    • BBF (Black Box Flashing) now handles controllers with corrupted serial numbers (i.e. for E54(LB7) and E60(LLY) controllers) the same as V7. That means if V7 was used in the past to license a controller with a corrupted serial number, BBF will now respect that license when flashing that same controller.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 246
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 238
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.06 (Aug 02, 2013
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.53 (Nov 19
    , 2013)
    Paul, thanks.
    Junior Member Alexander's Avatar
    Nov 2012
    Hurrah! Wow, E83 1.6 turbo, I've been waiting for this moment. The only pity is my operating system not supported yet.
    Really, what OS do you have? I know we only put two in this release and I must confess these are from the local Holden's when they changed to the E83 (1.6L) in 2013 from the E78 (1.4L). I suspect maybe you have an Opel?
    Nov 2012
    Yes, you're absolutely right, I have Opel Astra-j a16let E83A 12639834. I hope very much that receive support for this OS.
    Ah, E83A, that would explain it. Don't fret, we will get those done early/mid January (sorry you got all excited for nothing). December is a bit of a write off with us going to the PRI show.
    Member SGFastMax's Avatar
    Apr 2009
    Just to clairify, was the emissions removal options removed for all duramax controllers or just for the new lml?
    Scott
    Pre LML Duramax calibrations are still untouched for many years, LML never had any emissions defeat to begin with, not even in beta.
    Is there going to be a place we can get stock LML/LGH tune files?
    04 LB7
    2010 LMM
    2015 LML
    Apr 2009
    I second the above post^^^^
  1. Known issues with Nov 07 2013 release of the EFILive software and firmware.
    Last Post: June 14th, 2014, 10:53 AM
  2. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  3. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  4. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  5. BB Logging update Nov 28, 2007
    Last Post: November 30th, 2007, 09:00 AM
