Results 1 to 7 of 7
Thread: AEM digital WBO2 (Bosch 4.2LSU)
    Dec 2006
    Default AEM digital WBO2 (Bosch 4.2LSU)
    I will be working with this setup for the first time this weekend. Does this work well with EFILive? Does anyone have any experience with this brand and / or some tips on setting it up properly? Thanks!
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2006
    Quote Originally Posted by Boost View Post
    Dear Boost,
    You of all people should know not to be a dumbass and do a bit of searching before asking such a vague general question. If you did, you might have stumbled across this:
    http://forum.efilive.com/showthread....o-FlashScan-V2
    http://forum.efilive.com/showthread....&highlight=aem
    http://forum.efilive.com/showthread....ht=AEM+30-4100
    http://forum.efilive.com/showthread....nd-logging-afr
    http://forum.efilive.com/showthread....601#post149601
    Did you get it going...?
    Dec 2006
    Thumbs up
    Thanks for asking Joe! I'm going to be needing lots of your help with this.
    I am a bit embarrassed to admit that I have not done anywhere near as much of this as I should have and wanted to through the years. There's been too much wrenching 9-5 and diesel work to really get good at it. But now to propel my car and this other awesome one I'm working on to the next level, I must break down and get to it in 2014
    I have to start by finding my cables and adapters for the V2. I have moved I half dozen times since 2006 and besides my V2 and it's two basic cables in the Fish Tuning case, (and a few SD cards), I don't know where they are!
    Where is the best place to obtain a new serial cable and the little adapters??
    Also I must contact TAQuickness and purchase a harness yo work with. Next step is to read all 5 threads I linked in post #2 along with Shawn's thread at least 10 times...
    Bear with me! (insert growling bear smiley here)
    If you get a cheap ethernet jack crimping tool (that can crimp RJ11/RJ12/RJ45) then probably the best way is to make your own cable (follow the wiring from those AEM posts).
    Can get a crimping tool online... for example: http://www.ebay.com/bhp/ethernet-crimp
    The trick is to remove the cable sheath while not stripping the individual wires, push the unstripped wires ALL the way into the RJ jack (with Rx/Tx swapped appropriately or not), and then crimp.
    Dec 2006
    Smile
    Thank you for the great info as always Joe! I will definitely consider going that route, also looking at getting some of the stuff from an old friend.
    Dec 2006
    Update: purchased this! Thank you Joe for the great link. Looking to make progress on this car, will keep posted.
  1. LC-2: Digital Wideband, anyone try it out?
    By BlackGMC in forum External A/D inputs
    Last Post: March 19th, 2016, 01:28 PM
  2. Dakota Digital VSS
    By LS-SWAPPER in forum Conversions / Aftermarket Parts
    Last Post: December 5th, 2012, 05:02 AM
  3. Options for digital gauges
    By GMPX in forum Conversions / Aftermarket Parts
    Last Post: May 14th, 2012, 12:02 PM
  4. Digital Dash
    Last Post: January 5th, 2010, 06:44 PM
  5. Replies: 2
    Last Post: April 18th, 2008, 09:00 AM
