I should let you all know that there is a pretty major change to these torque table configurations coming which will mean if you have been scripting changes you will have to start again, the table configurations are changing.
I will shortly be in NZ working along side Paul on a few projects, one of them will be to plot the torque maps similar to how we do the Virtual VE's. However, at least for this trip there is no possibility of adding in the reverse calculations.
But the plan is what we can offer is a 3D plot of what the calculations will produce. We did some logging on Paul's car today (6.0L L98) and based on the numbers it was amazingly accurate.
So as another test I set up the calculation in Excel and punched in the numbers to match the L98's peak torque figure at 4,400 RPM from those in the torque model tables. I assumed a couple of things, timing (23 deg) airflow (860mg).
The L98's rated torque at 4,400RPM is 530Nm, the calculation produced 532Nm! If I dropped the timing back to 10deg it calculated out 436, upped it to a knock producing 30deg it only went up to 548Nm.
It's really fascinating playing around with the numbers and seeing the results, should be a lot of fun once it's implemented, but for the new ECM's (E39, E78 etc) pretty important.
It will be very tricky with the variable cam engines, it may take a few software revisions to get the operational side of this ideal based on everyone's feedback.
