Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Update: Jun 13, 2014
    Nov 2005
    Found another early TCM OS that doesnt have D5231 and D5233 that the late 01 and newer OS's have......15077860
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jan 2007
    I had to use 15196784 to see the TCC inhibit tables, its the OS that comes with efilive in the V7.5 bins folder. My stock 05LLY os 15175854 dosent have them either but it has to new release tables. The D5072 is also still not transposed like the other OSs but besides that it still dosent seem to help hard lockup anyway.
    Guys, that is just how it is, as code develops they add new functions in, we are not leaving things out on purpose, they don't exist.
    Mar 2009
    Quote Originally Posted by cmitchell17 View Post
    6784 is the 05 OS, the 5854 is the updated 01 OS with OD/LO enabled in it and is "THE ONE" that most everybody(including myself) switches over to and runs. Patiently waiting to see if it gets mapped out with the lockup tables as not getting lockup until the top of 3rd or on the 3-4 shift is annoying.
    Quote Originally Posted by THEFERMANATOR View Post
    From Ross's reply, it sounds as if the tables simply aren't there.....
    Nov 2005
    Ben, Ross attempted to apply all those tables - the ones we generally discussed in that thread and then your additional request made a few weeks ago to all OSs. They were applied where they existed.
    Cindy
    Mar 2009
    That sucks then because that OS is the one most all of us go to for the 5 speeds. It isn't the first 01 OS, but is the updated one that came out mid 02 to add in OD/LO and fix the 2-1 downshift clunk. It would figure the ONLY TCM OS that works in my BURB, is the one that doesn't have the feature in it.
    Jan 2007
    That explains why OD lockout didn't work, I guess I renamed it as my stock 05 os. The 15196784 seems to help the clunky 3-4, and slow down the 1-2 at part throttle, but at the same time it shifts hard at low throttle for the 4-5. It seems like theres just no good OS, but this one is the only one I see available that has the inhibit tables.
  9. #19
    Gone through a few LML OS's and noticed that table B1108 and B1111 are the exact same table? It only lets you have one or the other open at the same time, but you can edit them seperately but they are labled the same "Smoke Limiter, Regen 2" Tho I think B1111 should be "Smoke Limiter, Regen 3". Just wanted to make sure this wasn't a typo/mistake.
    It is a labelling error, B1111 should indeed be "Smoke Limiter, Regen Mode 3", it is odd that that table isn't opening up anyway, I changed the label and that fixes it.
    Thanks,
  10. #20
    Update available here:
    https://forum.efilive.com/showthread...te-Jun-16-2014
    Please be sure to read the important warning about tune file compatibility before updating.
  1. 2014 silverado
    By gypsy06vortecmax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 13th, 2014, 04:22 AM
  2. Update: Jun 10, 2014
    Last Post: June 12th, 2014, 11:48 AM
  3. 2014 gmc 5.3
    By dkeven@gmail.com in forum Petrol / Gas
    Last Post: May 23rd, 2014, 10:28 AM
