Page 7 of 7 FirstFirst ... 567
Results 61 to 69 of 69
Thread: New member looking for some input on tune
  1. #61
    Yes, just minorly tweak portions of the VE table (rule of thumb: if Calc.VET produces a good smooth MAF with correct IFR data, and the produced VE table is dubious, then make your own adjustments to VE... you will eventually have to isolate VE (disable MAF) and tune it using Calc.MAFT.
    Also, did you remember to apply the transient filter before applying the maps to the tune (as shown in the Calc,VET thread)...?
    If the AFR (or Lambda) did not reach the PE commanded richness level, then either the air model is still not right, or PE ramp in is too slow, or the wideband is not reading correctly
    ( make sure you use Lambda from the wideband and avoid AFR ).
  2. #62
    Nov 2014
    I am thinking the pe ramp is just a bit slow. It did go and I was able to achieve 13.2 for a very short period. I didnt really stay in it though to find out.
    I fallowed the filters on the thread.
    I added 1 percent to the lower kpa section and 2 percent to the larger kpa section and blended the middle to keep it smooth and I noticed that the LTFT's went to 1-1.5% at lower rpms and only up to about 4 percent in the higher rpms. I think a touch more and I will just leave it alone and call it good. Then start tinkering on the spark tables.
    Then I suppose I would have to relook at the fuel again once I touch spark?
  3. #63
    Nov 2014
    The Afr appeared to be working correctly. It was constant 14.4-6 for most all throttle levels until the pe activated.
  4. #64
    Aug 2013
    OR... maybe it's because he's plugged his wideband sensor into his rear o2 sensor bung.
  5. #65
    izcain, do you have cats on the vehicle...?
  6. #66
    Nov 2014
    Yes it still has the factory cats and exhaust on. Maybe cats are changing afr for the readout on the wideband?
    Is the rear o2 not a viable place to put the wideband? Or can I do this but make the difference by turning off that cat protection?
  7. #67
    Nov 2014
    So I thought I would give an update. I have slowly been creeping up on the fuel table and am almost complete with that side now I believe. I filled up after running thru a tank of fuel and I had to double check my math since I had a hard time believing it. Before messing with tune it was about 15 and this last tank I have a hand calculated 18.59 with an extremely light foot! I have yet to add much timing (non to be exact yet) but I am very happy with the improvements so far!
  8. #68
    Thanks for the update
  9. #69
    Nov 2014
    Thanks for the help!
    I think with some timing added to the table I may be able to squeak a bit more. It would be awesome to be able to knock down 20's out on the highway!
  1. Help give input to my tune/scans- OL AutoVE/AutoMAF
    By ddnspider in forum Gen III V8 Specific
    Last Post: August 7th, 2013, 11:04 AM
  2. Looking for tune input
    By devlmaycry in forum Gen III V8 Specific
    Last Post: January 29th, 2012, 10:04 AM
  3. new member
    By Baldric in forum Tuning For Economy
    Last Post: May 4th, 2009, 03:18 AM
  4. ** New Member **
    By Nemo in forum Lounge
    Last Post: November 16th, 2008, 08:59 PM
  5. New member, need some help to get going....
    By doorunrun in forum EFILive V4
    Last Post: February 11th, 2008, 02:40 PM
