Results 11 to 20 of 25
Thread: O2 voltage logs but doesn't show up in scan and tune chart
    darcy, how do you get the V8 scantool to replot (after adding pids to a chart)...?
    Feb 2012
    I'm not really sure, Joe.
    My chart seems to plot automatically as soon as I select a different pid.
    Hmmm, I can't get it to replot.
    Also, I can't seem to see how to add more charts...
    Feb 2012
    You can right click on the charts and select Options from the context menu, then select Chart Properties or Shift+F4.
    In there you can can increase the number of charts.
    May 2012
    Just finished installing the new updates.
    So I think you can see my problem joecar, I can select the o2 pid, but the data doesn't plot like it does for darcy.
    I have tried playing with chart options, but nothing seems to make the data visible.
    Quote Originally Posted by darcy View Post
    Ah, I see it now.
    Paul,
    Attached pic shows two pids (O2S11, O2S21) not plotting.
    (also, btw, when in small icon mode, some of the labels are missing )
  9. #19
    Paul,
    Investigating the non-plotting PIDs...
    In small button mode the labels are deliberately not shown, there's not enough room.
  10. #20
    Paul,
    Confirmed, it is a bug. Will be fixed in the next update (due Monday).
  1. added lc-1 serial PID but doesn't show up on dashboard
    By Bill00Form in forum FlashScan V2
    Last Post: November 19th, 2011, 10:36 AM
  2. Scan Logs are limited in size or frames
    By Chalky in forum General
    Last Post: July 13th, 2011, 04:49 PM
  3. FUELQ_MAIN_DMA doesn't show up
    By THEFERMANATOR in forum Black Box Logging
    Last Post: September 21st, 2009, 01:53 AM
  4. Scan doesn't work after upgrade
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2009, 03:11 PM
  5. Scan doesn't find PCM - but everything else works ...
    By Garry in forum FlashScan V2 BB Logging
    Last Post: May 17th, 2008, 02:27 AM
