Results 11 to 20 of 33
Thread: Known issues with April 13, 2015 Public Release
    Jul 2012
    in E92, OS 12663390, the SIDI Injection timing units appear to be incorrect (ie table B1531 shows degrees, but an input range of 0-512 is shown)
    Also, and I apologize if this has been discussed elsewhere, how long till BB logging of E92 is supported? My laptop battery life is terrible.....
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Quote Originally Posted by Wheelz View Post
    The E92 calibrations are scheduled to be updated in the next auto-update. We hope that will be within the next couple of weeks.
    The E92 has supported BB logging for a long time now.
    To add BB logging support for a controller, you need to add it to the blue section of the [F5: BBx]->[F2: Scan] tab page. To do that, click on the green (+) button, then right click on the left-hand grey box and select E92.
    Jan 2009
    Just updated to the new S/W and quickly discovered a PIA issue. In the update (apparently) file properties are automatically set to lock a file to one's V2. I can see where that would be important to a professional. It is not to me as I share files with others. This led to frustration for folks I was trying to help and to me while trying to figure out what went wrong. One has to change properties to allow sharing. It would have been nice to be asked about security properties during the S/W update installation process.
    Quote Originally Posted by Yellow05C6 View Post
    Please read the release notes: http://download.efilive.com/Software/whatsnew_275.html
    IMPORTANT
    Your security restriction options on the [Permissions] tab page in the V7.5 Tune Tool software may change during the upgrade to this version of the V7.5 software. Please review those security restriction options and reconfigure them according to your preference.
    Jul 2012
    Thanks Paul! I completely missed the that info!
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Oct 2006
    After updating to this April 13th, 2015 release I had a error again, this time I remembered most of it -- opened V8 software (Scan and Tune), a pop-up window informed that firmware was outdated, updated firmware got green okay, after pop-up window closed I clicked the "check firmware" balloon button within the Scan and Tune window, a pop-up window opened again, firmware indicated still okay but was prompted that there were errors in some config files, indicated by red check marks beside several of them (configuration files), nice this happens now, would be nice to see an automatic check of config files after a firmware update seeing that wrong config files can cause a no flash problem, or is there one, automatic config file check? Config files were rewritten and all were green.
    Have looked for fuses that were indicated to be a problem in the P12 flash and read, none resemble the ones mentioned in the Support answer.
    Am I going to get a nasty surprise tomorrow when I try and do a cal flash? Like a none supported controller error.
    I rebuilt (as in took the trans out of vehicle, tore it apart, cleaned, used rebuild kit to reassemble) the 4L60E in the TB and needed to lower line pressure from an earlier tune, with the new bands and Transgo shift kit I don't need the pressure up any longer.
    I noticed in the "Supported Vehicle" list TB says 08-09 only now.
    2006 Trailblazer
    What does that mean? You couldn't find any of the ones people suggested?
    Oct 2006
    I don't know, was the Support answer posted here? I didn't think I posted it here. Then I guess not.
    Help me out I am stupid and can't find the answer.
    AASQGASA
    2006 Trailblazer
  9. #19
    Some suggestions were posted to your post in the RC1 thread -
    https://forum.efilive.com/showthread...didate-1/page5
    Specifically post 46 which has some links to posts suggestion specific fuses.
  10. #20
    May 2010
    AASQGASA
    So how did it read/ flash after you pulled the fuse? What fuse fixed your read/flash problem?
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  1. Known issues with March 2015, Release Candidate 1
    Last Post: April 10th, 2015, 10:03 AM
  2. March 2015, EFILive Release Candidate 1
    Last Post: March 20th, 2015, 07:04 PM
  3. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
  4. Known issues with Feb 2015 release of the EFILive software and firmware.
    Last Post: February 9th, 2015, 11:53 AM
  5. Known issues with Jan 2015 release of the EFILive software and firmware.
    Last Post: February 4th, 2015, 06:55 PM
