Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: Looking for some help on cam/headers tune LM7 5.3L (mostly spark)
  1. #31
    Jun 2015
    BTW, here was the results from the dyno. Again, it's a 2002 5.3L, Texas Speed 220R 220/220 .581 lift 112LSA camshaft, American Racing stainless longtube headers with high-flow cats, and 3in dual cat-back with 2x Flowmaster Super 40's, Outlaw Racing cold air cleaner / intake setup, 30ish thousand miles.
Name:	dyno chart1.jpg
  2. #32
    Aug 2013
    The AFR's on that dyno sheet don't look very good.
  3. #33
    On NBO2 only (i.e. no wideband) you can't easy correct during OL (non-stoich) conditions.
  4. #34
    Jun 2015
    Hmm...statesman,
    The red line was the last pass. Is that still too lean? What should my AFR's be looking like? I know they need to be richer, but should they flat across the power band or should it vary, i.e. rich, but a richer toward peak tq, and a bit leaner towards peak hp?
    Joecar, not sure what you mean there exactly. I know he needs to get the wideband back in there, but is there a way to do calc.vet correctly with only one NBO2? Otherwise, pretty much waiting he can get a third pre-cat bung installed, right?
  5. #35
    Jun 2015
    So basically where I am at is this: The whole time I was tuning the truck, using calc.vet, there was one narrowband (on bank 1 I think) and there was the wideband where the other NB should be. I was thinking both NB's were still installed in addition to the WB. I did calc.vet and it spit out the values for the VE table, but only 0's for MAF correction. I don't fully understand how it works, but obviously calc.vet looks at both bank 1 and bank 2 NB's.
    Is there a way to fix this using old logs using data from the one NB that was there? i.e. is there a way to fix this without having to start over? I burned up my "free day at the dyno" card here. Starting to be pretty concerned, I could sure use some help here.
    Does this make sense? I feel like I'm not explaining the problem well.
  6. #36
    Jun 2015
    Calc.vet only uses the NB's to correct MAF, right? So doing calc.vet with one NB missing would still generate correct VE values, just no MAF table correction, so do I just need to correct the MAF tables ?
  7. #37
    Aug 2013
    Quote Originally Posted by 96SWB View Post
    Hmm...statesman,
    I think that it should be somewhere in the 12's. It's personal choice whether you run it flat or vary it. I choose to vary mine. How you set it and what you set it at is entirely your choice but 12.8 in the lower rpms varying to 12.2 in the higher rpms is usually considered safe. I certainly wouldn't want my AFR in the 13's at full noise.
  8. #38
    Aug 2013
    I don't know what you did with your free dyno time, but it looks like you were not very well prepared for it. You really need to sort the fueling out first, then use the dyno to dial in the spark.
  9. #39
    Yes, you can use only one NBO2, you have to edit CALC.LTFTBEN's CLC to use only one NBO2...
    Ok, I see, the wideband was being used...?
    Yes, edit calc_pids.txt and revisit the log files...
  10. #40
    Calc.VET uses NBO2 and WB to correct the MAF table and to generate the new VE table...
    in the calc_pids.txt file edit CLC-00-120 as follows:
    Code:
    *CLC-00-120
    factor             0.5           1.5       .4  "{SAE.LONGFT1}/100+1"
  1. Startup issues on 03 LM7 with a small cam?
    By LS1FREEK in forum Gen III V8 Specific
    Last Post: June 3rd, 2013, 12:08 AM
  2. 6.0 with procharger, cam, heads, headers, 30 over, 60lbs injectors,2 bar and lost
    By oldblue_6 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2011, 01:13 AM
  3. 99 ls1 cold air, headers , and exhaust tune?
    By hdsvette in forum Gen III V8 Specific
    Last Post: September 28th, 2010, 05:12 PM
  4. Injecters and headers installed! do i need to change tune?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 5th, 2009, 07:31 PM
  5. Need tune for Hotcam, Headers, Stage 3 heads!!!
    Last Post: October 13th, 2005, 05:09 PM
Tags for this Thread
