You were right I changed the B4205 table but forgot to Enable B3801
Ok, good job on getting it going
(sometimes can't see the forest for the trees... or is that supposed to be vice-versa...?)
in this tuning world its vice versa haha. LTFT's are 3.9 and average BEN is .98 so for my first shot im happy with that. I have attached a log for confirmation of my happiness. Thanks again mate.
maflessltft.efi
I haven´t try AutoVe until now, I did follow the tutorial and unplug the MAF, but when I try to start the engine it won´t start. Until I plug the MAF again, I Re-check the file and looks like is suppose to be.
I must be missing something. Any advice?
With the maf is it a 3 wire or 5 wire?
Upload a copy of the tune file of you can.
Here is the Tune
Doc SD AutoVe_0000.ctz
Will check it this arvo when I get to a computer.
everything looks set up right in the tune, what has changed in the tutorial from what Joe has showed me is with B3605 leave this factory and change B3618 to 1.17. When you say the car wont start does it turnover and just not fire?
