Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 124
Thread: E38 VVE Setup Guide
  1. #81
    May 2009
    Yes, I got that. I did some testing last weekend and setting "DTC Type" to "X: Not reported" is not very helpful. there are 2 possible results from doing this.
    1. If the MAF is still plugged in correctly and functioning, it will still be used for air flow measurements as you have just told the ECM to ignore any MAF failures. So it will continue to use the signal coming from the MAF, even if the test settings say it should have failed.
    2. If the MAF has been disconnected, the car will start and then stall as it will get no fuel. As the PCM has been told to ignore MAF failures and the MAF is disconnected, it will read the air flow as the minimum MAF setting ( in my case 0.55 gm/S ). Given the very small airflow being used, the PCM will simply not inject any fuel and the engine will stall.
    So the idea would be to set the following:
    If you are planing on going back to using the MAF, the changes should be...
    DTC MIL - P0101 = No MIL
    DTC MIL - P0102 = No MIL
    DTC MIL - P0103 = No MIL
    and optionally
    DTC Type - P0101 = C: Non Emissions
    DTC Type - P0102 = C: Non Emissions
    DTC Type - P0103 = C: Non Emissions
    All these will need to be returned to stock when the MAF is returned to service.
    If you are going to remain MAF-less...
    Is this the case for the E67 as well? Will it be consistent that the engine won't start? Or could it start and run fine at times?
  2. #82
    Senior Member MyM8V8's Avatar
    Aug 2008
    Guys. Will the Efilive VVE tutorial and Swingtans VVE set up still be ok for a 2015 Gen F Maloo (R8 SV pack 340kW. T43 6L80E).
    Thinking of smallish cam, intake and CAI with 1 7/8" LT headers and 3" duals.
    Thanks.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
  3. #83
    Bump again.
    Links for easy reference:
    E38 VVE Setup Guide
    Virtual VE Tutorial
  4. #84
    May 2015
    Couple of questions on this tutorial, It says to alter the VVE above normal RPM range and also in the low MAP area - What is a suitable value here?
    Once finished with the VVE correction which tables are returned back to factory when staying SD (MAFless). It also mentions resetting AFR's - Is this back to factory in the B0141, B0143, B0146, B3618? Im sure i will have more as I get my head around the VVE system rather then the old LS AutoVE way.
  5. #85
    If you want to run MAF-less, you leave the MAF failed (with MAF DTC showing up).
    If you want to run CL you have to restore the settings for the CL/LTFT/STFT tables that you disabled to do VVE.
    After flashing, you use the scantool to reset trims.
  6. #86
    May 2015
    So it is very much the same as the Auto VE except the smoothing part. So I leave the AFR tables so it's either commanding 14.5 cruise or 12.5 WOT? Or do I return these to the factory settings aswell?
  7. #87
    Yes, it's very much the same as AutoVE.
    Yes, leave the cruise/PE tables set at 14.5/12.5 (and verify that you see these values at the wideband, if you do then it means the VE/VVE is close).
  8. #88
    May 2015
    Yep have been doing that and it's getting close some mid throttle points around the 3-4K rpm range it's up around the 15.3 AFR so needs some work in this range. I have my E38 BEN Map set up showing 3 decimal points and used the copy and fill process to hit some areas I didn't get up to the 50 count. I also went from 6400 rpm and I copied and pasted into the next rpm range and took 1% and continued this right up to 8000rpm to flatten off the end of the VVE table. I will go for another log tonight hopefully temp drops as its 37 hear today.
  9. #89
    May 2015
    Also once in OL does the engine run only in the low octane spark table like the ls1?
  10. #90
    May 2015
    You say mafless you just leave the maf failed? I'm still able to be mafless and run my LTFT and STFT is this correct? So would this make it a CL SD Tune? And by being in CL with STFT active will account for IAT temp changes? Sorry if this seems dumb.
  1. E38 / E67 VATS disable guide
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 22nd, 2023, 01:35 PM
  2. Tuning Beginners Guide
    By NASABlue in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 02:37 AM
  3. Beginners guide to tuning
    By ringram in forum Tutorials
    Last Post: June 17th, 2006, 10:46 PM
  4. Draft LC-1 Guide
    By 98WS6_JPM in forum General
    Last Post: May 12th, 2006, 02:53 AM
  5. PCM tuning guide
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2004, 05:42 AM
