Results 11 to 20 of 52
Thread: Migrate from HP tuners to EFI Live HSV VE 6.2L Heartbeat sc
    Junior Member rich24v's Avatar
    Jun 2011
    If you're located in Aus, you can maybe get one with cheaper shipping by contacting EFILive support.
    I'm UK based, but think I found one from a UK source:-
    http://uk.rs-online.com/web/p/non-fu...locks/0171691/
    Might give them try.
    UK spec 2009 HSV VXR8 6.2 LS3, E38, HeartBeat Supercharger running ~9psi,1 7/8" long tubes, cat back exhaust.
    Upgraded cam and springs of unknown specification, all I know is, it's a small cam with no overlap, suits the s/c.
    ATI damper, LS9 twin plate clutch, 548rwhp. twin PLX widebands to twin gauges.
    Currently running dismal HPTuners....NOW DUMPED !, Completed migration to EFIlive and slowly mapping it in.
    628rwhp.....with a lot of tuner help
    UK#3.826 (US$5.50) is a reasonable price.
    Jun 2011
    Update post for me, info transferred from another thread:-
    joecar
    Connect 1st PLX to AD1+ signal and AD1- ground.
    Connect 2nd PLX to AD2+ signal and AD2- ground.
    Log the pids EXT.AD1 and EXT.AD2.
    Select the calc pids CALC.AFR_PLX1/2 and CALC.BEN_PLX1/2.
    In FVS2 device settings, checkmark the box to always include External Analog Pids.
    Rich24v
    Thanks Joe, think it worked out ok, although more fumbling than knowing what I'm doing
    I had to remove some odd pids that it did'nt like, maybe that's because I still have the HPtuners 2bar custom tune loaded,
    but at least I am slightly further forward. I can't see the BEN pids...are they to convert the voltage to the AFR ?
    I have boost via plx and fuel pressure via aeroforce 150psi sensor to set up next.
    joecar
    On the PIDs tab, look at the right-hand column, it is titled "Parameter", click on the title (the word "Parameter") to sort alphabetically on that column...
    then look down that column until you see the pids CALC.BEN_PLX1 and CALC.BEN_PLX2...
    the BEN pids are the correction multiplier, to see their definition do rightclick->More Info on each of them (on the PIDs tab).
    Summary: the AFR pids convert voltage to AFR; the BEN pids calculate the correction multiplier (to apply to your VE or MAF tables).
    Rich24v
    Do I have to add these pids to the list ? if so I get error :-
    If I add anyway, it lists it with the red cross through it:-
    A bit lost..........
    joecar
    I don't remember from your other thread... do you have an LS1B or an E38...?
    Whenever you see a red X thru a pid on the PIDs tab, on that pid do rightclick->More Info to see why.
    Jun 2011
    Joecar,
    its a E38 (I put details in signature line, does it show up there ?)
    Jun 2011
    I can see the error for the pids with red cross, some missing pids which I loaded in.
    The last one E38.AFRATIO_DMA won't display a error:-
    Jun 2011
    Quote Originally Posted by rich24v View Post
    Yep, these are the ones, had to buy 5off pack, so unlikley as it maybe, if anyone else in UK wants one, contact me.
    Try to log it anyway, see if it logs, post a log file.
    From the list of pids you show, remove these pids (keep the others):
    GM.ETCPED
    SAE.TP
    SAE.TP_B
    SAE.AAT
    (unless of course you're interested in these pids).
    and add these pids (in addition to what was kept):
    GM.ETCTP
    SAE.LAMBDA
    SAE.SHRTFT1
    SAE.SHRTFT2
    E38.APCYL
    E38.SCALEDCORVE_DMA
    E38.SCALEDUNVE_DMA
    GM.HO2S11
    GM.HO2S21
    GM.INJPWB1
    GM.INJPWB2
    GM.KNKRET
    also see if any of these log (additionally):
    GM.DYNAIR
    GM.DYNCYLAIR
    GM.KRCYL
    We want to see what tuning-meaningful pids your ECM can produce.
    Remember to save the list of pids (click the Save As button on the PIDs tab toolbar, give it a meaningful filename).
  9. #19
    Good job
  10. #20
    Joecar,
    lol, sometimes my focus is too narrow.
  1. Hp tuners to Efi live
    By madmax4499 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2012, 05:51 AM
  2. Is HP Tuners better for gas engines than EFI Live?
    By Texas Edition in forum Petrol / Gas
    Last Post: August 13th, 2012, 08:38 AM
  3. Why 2 Buy EFI Live instead of HP Tuners?
    By DMAX432 in forum General (Diesel)
    Last Post: May 24th, 2010, 05:31 PM
  4. EFI Live / HP Tuners stacked
    By SRT10KLLR in forum E37, E38 & E67 PFI ECM's
    Last Post: December 9th, 2009, 09:52 AM
  5. EFI Live Tuners in Perth?
    By 4wheelin in forum Gen III V8 Specific
    Last Post: September 27th, 2009, 11:38 PM
