Page 19 of 19 FirstFirst ... 9171819
Results 181 to 186 of 186
Thread: LC-1 widband hook up
  1. #181
    Feb 2007
    I had figured this out... but I had not run across the rest of Dr.Mike's advise... I'm going to try the resistor/capacitor.
    If you can share the details of the source for resister and capacitor you use id be grateful, i had a look online but not sure exactly what to order?
  2. #182
    Quote Originally Posted by Gelf VXR View Post
    I would probably try a 3.3ohm 1/4W carbon film resistor and a 10uF multilayer ceramic capacitor.
  3. #183
    For example:
    cap
    res
  4. #184
    Feb 2007
    For example:
    cap
    res
    Great, thats exactly what im looking for
  5. #185
    Feb 2007
    Hi Joe, Ive got to re order the caps as i have lost them, there out of stock til end of the year thou, can i use an electrolytic capacitor instead, whats the difference in this application?
    Ive got two LC-1's, one has the green wire, the other is without, so i want to wire them both the same using the cap and resister on the white wire.
  6. #186
    You could also use tantalum caps.
    You could use electrolytic caps but they have a bigger size (won't tuck so nicely into wire harness).
  1. LM2 > Flashscan hook up
    By AGRO in forum External A/D inputs
    Last Post: December 27th, 2010, 09:34 AM
  2. How to hook up AEM wideband to interface? help
    Last Post: October 11th, 2008, 06:16 AM
  3. lc-1 to v2 hook up
    By W_D_R in forum General (Petrol, Gas, Ethanol)
    Last Post: March 31st, 2008, 03:42 PM
  4. LC1 hook-up/installation
    By SPRAYED07 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 8th, 2007, 07:36 AM
  5. lc-1 WB hook up to old O2 wiring?
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 03:44 PM
