Results 1 to 10 of 11
Thread: MPH on Log doesn't match timeslip
    Senior Member TLKSCHP's Avatar
    Dec 2005
    Default MPH on Log doesn't match timeslip
    Anyone have a discrepancy from what you show in the log versus what your 1/4 mile time slip shows?
    Time Slip is showing 129 MPH at 11.45 but my max MPH in the log is 122 and that's after the 1/4 mile.
    also my RPM's seem to be off at 122 in my log I'm at 6328 which should only be around 5600.
    I went out with my GPS and driving it reads within .5 mph. Trans isn't slipping
    Boosted 98 C5 Corvette with 02 PCM running COS
    Yank PAS3400, 231/239 617/623 114
    A&A kit Vortech V3 hitting 10psi
    3.73 gears 27.2'" tall tires
    checked with others logging at the track and they don't have any issues
    Yes I'm aware of the injector duty, that doesn't add up either. 60lbs siemens
    Last edited by TLKSCHP; June 14th, 2016 at 07:02 AM. Reason: added log also added tune
    What laptop are you using (is it fast enough)...?
    Dec 2005
    Samsung 1.8 AMD A8 6 gig ram win10
    That should be sufficiently fast.
    Maybe try to sanity check using landmarks separated by a known/verified distance...
    check at 60, 80, 100, 120 mph (if you can).
    Dec 2005
    I will give anything a try at this point. My rpm is killing me also. its set to shift at 6500 but doesn't until 7000. Originally had it at 6800 but was shifting at 7400 according to the log
    Quote Originally Posted by TLKSCHP View Post
    Set the WOT MPH shiftpoint a lot lower, and then fine tune the WOT RPM shiftpoint (or vice-versa).
    Dec 2005
    I have it about 20mph below now but someone else was telling me they had to go all the way to single digits
    Post your tune file.
    Dec 2005
    I added the tune and some more info about my car to the first post. Well i feel stupid, i double checked and my 20mph buffer wasn't that, it was allot closer. So i will get that adjusted and focus on why my rpm & mph seems off. If anyone wants look through the tune feel free, I'm new to boost and in way over my head with this tuning but all the shops around me Use HP and i like the efi live COS better so I'm on my own with no dyno.
    Thanks again as always for the help and support
    John
  1. PLX Wideband doesn't match?
    By 2ktransam in forum General
    Last Post: March 8th, 2013, 09:01 AM
  2. GM.AFR problems?? Commanded doesn't match B3618
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: April 6th, 2011, 07:47 PM
  3. Timing in tune doesn't match log...
    By LS1FREEK in forum Gen III V8 Specific
    Last Post: August 28th, 2010, 08:43 PM
  4. Another lc1 question.. afr doesn't match on v2
    By picnic_george in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2010, 07:47 AM
  5. Main VE doesn't match MAP.SAE
    By LSs1Power in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2007, 03:11 PM
