Results 1 to 9 of 9
Thread: Dashboard in Scan Tool
    May 2006
    Default Dashboard in Scan Tool
    My needles have disapeered in the dashboard. What the heck happened? Now when i try to moniter the engine it will go straight to pause. (I assume that it goes straight to paus is because there are no needles in there.) Another thing is a couple days ago i did the personal to commercial upgrade that came with my EFI Live.
    02' T/A convertable,ram air,Procharger-D1SC,dual intercooled,Patriot stage 2 heads,small comp cam,childs & albert rods,forged pistons,fast ls6 intake,90mm throttle body,NOS,TH400,2500stall,trans brake,moser rear w/4.10's,tubeler upper & lower A-arms,QA1 raceing shocks,tubeler drive shaft loops,subframe connecters,OK to much to list.There is more!! Dynoed @ 520hp & 580tq. at the tires without nitrous.6.9@93mph 1.7 60ft. in 1/8.
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Im sure there are other and probably better ways to do this, but I'd start by verifying that you're using the latest release of both the scanning and flashing programs. You may be experiencing an incompatability problem between versions. You can download the latest at http://forum.efilive.com/showthread.php?t=2430.
    Try that for openers.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    May 2006
    Ok simple enough. Which one do i download? (I am new to this stuff.)
    Also, try pressing the yellow or red button at the bottom of the scan tool and see if this helps
    Jan 2005
    Download the April 26 release and follow the installation instructions. Then do the same with the May 03 updates.
    678/344-1590
    May 2006
    Yea that fixed the problem!
    May 2006
    Quote Originally Posted by 02' Hawk View Post
    Ok guys sorry for the same question again. My last laptop had a hard drive crash. I now have a new laptop and the SAME ISSUE is happening again. I tried to do the update (that fixed it last time using the link above) but no luck. It's done expired on that page or something. Any new update links?
    Nov 2006
    Because that link and this thread are super old.
    Try this.
    EFILive V7.5 Scan And Tune Software For FlashScan V1, V2, AutoCal And AutoTap
    LC-1 WBO2
    May 2006
    Thanks man. Just found it and it's at 50% already. Thanks again for the quick reply.
  1. Tuning tool not following scan tool (VE table)
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2008, 09:43 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
