Make sure that P0101, P0102, P0103 are disabled in these tables:Originally Posted by mtnman
E0101, E0102, E0103, E0104
edit: and check for any instances of P0101, P0102, P0103 in any Exxxx tables.
(they don't appear in all these tables)
Also "broken" is GM.TFMPRS (psi is ok, but kPa is wrong).Originally Posted by joecar
Both will be fixed in the next release.
Paul, thanks mate, excellent customer service.Originally Posted by Blacky
I experimented a little, and I found that I can eliminate the clunk most of the time if I revert back to stock the lower portion (TPS < 25%) of the PT 2-3 upshift table D0902 and the PT 3-2 downshift table D0907. It still happens, but less frequently and less pronounced when it does.Originally Posted by Flyer
I spend about 30 minutes/day in 0-25MPH stop/go conditions (freeway traffic jam) so I get good opportunities to test this out.
So I don't know if your tables are modified, if they are you may want to try this.
Well, thanks for the help you guys provided me without even knowing it. My 02 TrailBlazer with Transgo HD-2 shift searches for gears on the hwy and above about 45mph, but after reading this thread I have some ideas that I am going to try tomorrow and see what happens!!
Let us know how it goes/went...Originally Posted by ScarabEpic22
Hi there guys.
Did my first trans tune on a VYII Holden R8. Interesting experience with very good results!
The trans had the usual clunky down shift and slow sloppy upshift under hard acceleration. It also had that annoying TTC lockup in 4th gear that won't unlock when you hit a decent hill unless you really stab the throttle or pass 50% TPS or more. This means you are always reaching for the manual change to 3rd or suffer in silence and slooooowwww down
What amazed me was how different the car was to drive once we "got it right" !
The Upshifts were snappy yet not jerky giving a performance feel, the downshifts on light throttle were almost imperseivable, the TTC was hardly noticible on lockup.
And best of all, the moment you hit a hill and needed a bit more grunt the TTC unlocked at about 40% tps (standard about 52%) and away you went. The customer was very impressedand so was I.
Thanks for all the good info and tuning tips on this thread !
Mike
"Just a tune > yeah right !!!! "
forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
This is a old thread.....![]()
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System;
Tinted Windows 35%;EFILive Tune
