Results 1 to 5 of 5
Thread: Address range out of bounds
    Member koolky's Avatar
    Aug 2013
    Default Address range out of bounds
    Error:
    User defined definitions for most older controllers may be defined outside of the calibration data area by checking the option: View->Properties->[Options]->"Allow *.cax files to modify operating system memory for some controllers."
    I have that option checked off but it still wont let me load that address. Is there another way around this? I understand the address is off limits to prevent a .cax error from bricking an ECM but I'm confident that the changes made wont lead to that. Currently working with LBZ ECM.
    Aug 2013
    I've been rescaling axis' and it'd be handy to be able to modify this address range with a CAX vs alternative programs.
    Address Range Report
    The following calibrations have been excluded:
    - User calibration: 1D4F54 address range $1AC004..$1AC016 is out of bounds.
    Quote Originally Posted by koolky View Post
    Is this still for LBZ? Because that address range should be valid, it should not be reported as "out of bounds" for LBZ.
    Can you send me the cax definition and the *.ctz file that you are working with and I'll see if I can figure out what the problem is?
    Send to paul@efilive.com
    My Mistake, that address is out of bounds for LBZ.
    You can't create *.cax definitions for the DSP2 or DSP5 calibrations. You can only create cax definitions for the stock calibrations.
    Aug 2013
    Ok, thanks for looking into it for me. I get why that range is protected. I've had luck rescaling the axis' and logging up to 200mm3 in the original tables but as soon as the DSP range is modified the file opens without the DSP tables visible.
  1. Access Violation At Address
    By shotgunbob in forum AutoCal
    Last Post: March 31st, 2015, 07:11 AM
  2. $31 out of range
    By pdasterly in forum FlashScan V2
    Last Post: October 14th, 2013, 06:01 PM
  3. Out of range
    By w/t1500 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 7th, 2011, 12:26 PM
  4. LTFT - range vs + range lean rich question
    Last Post: September 14th, 2009, 06:18 AM
  5. A0011 out of range...
    By brokenfly in forum Custom Operating Systems
    Last Post: October 16th, 2007, 08:35 AM
