Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Idle Fuel smell
    Quote Originally Posted by statesman View Post
    It's a mis-labeled table. Those numbers are in references pulses. Each reference pulse is 90 degrees of crankshaft rotation. Higher numbers mean the EOIT is later, lower numbers mean the EOIT is earlier. Most people can't figure it out because there's an offset. Someone did some physical testing over on the HPT forum a while ago (I think it was Bluecat) and the results of the test showed that it is reference pulses and that there is an offset.
    Which valve event is the zero reference...?
    Aug 2013
    The zero reference point is not a valve event... it's a crankshaft position relative to the tdc position of the cylinder being fueled.
    Here's the thread on Bluecat's bench test...
    https://www.hptuners.com/forum/showt...OI-fuel-timing
    Have a read and let me know if you're still lost.
    Ok, thanks, I'll read carefully.
  1. Fuel smell at idle
    By picnic_george in forum Gen III V8 Specific
    Last Post: August 18th, 2021, 03:28 AM
  2. Fuel smell from engine side
    By ronaldsimmons in forum Lounge
    Last Post: September 7th, 2016, 06:40 PM
  3. Idle fuel trims in the negatives. how far is too far?
    Last Post: July 26th, 2015, 03:04 PM
  4. 05 GTO idle/fuel problem
    By slowhawk in forum Gen IV V8 Specific
    Last Post: March 30th, 2008, 01:36 PM
  5. idle fuel efficiency?
    By turboberserker in forum Custom Operating Systems
    Last Post: February 16th, 2006, 07:13 PM
