ok here is org tune and trans tunes
I never did get throttle over 80% until I turned the maf back on,535 HP In 4th gear 6 lbs boost.
560 hp in 3400 lbs car will run 130 1/4 mile speeds off my dyno.
Now I have tire spin problems
Interesting regarding the MAF-ETC correlation, thanks for posting back.
The MAF ETC correlation is easily fixable by setting b8303 to 200
I'm having a problem getting the Joecar file to work from post #18
I pasted the file into the appropriate folder on my computer and the car I'm working on does not see me datalogging the appropriate cells.
Am I doing something wrong?
On another note, I can't seem to get the B1099 to map on the file as well
MAFFREQ vs Grams/Sec
I can only select MAFFREQ2 in Scan Tool. I'm thinking that may be my problem.
I have too much datalogging because I've been trying different things. But here are my files. Thank you!
E92 - 2017 CAMARO ZL1 A10 (12682377) - STOCK FILE.ctz Log_0145.efi
Hi GR8GAME,
did you place that calc_pids.txt file (from post #18) into the folder C:\Users\<you>\Documents\EFILive\V7.5\User Configuration...?
when you open the scantool, goto the PIDs tab, click on the column heading Parameter once or twice to sort on that column...
then look down that column and find the pid CALC.MAP_BARO.
