Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: V1 stopped letting me flash my pcm
    Jan 2020
    What PCM type are you using?
    Can you check to see if a trace file was created in the folder \Documents\EFILive\V7.5\Bug Reports. The trace file will be named something like "20190926_120523_download.blx"
    Where the numbers refer to the date/time that the trace file was created.
    If the trace file exists, please email it to me paul@efilive.com.
    Are you able to log data from the PCM - i.e. do any communications between FlashScan and the PCM work?
    Thanks for the reply!
    Something got upset and it all stopped working. I disconnected the batteries. For four hours I tried every possible option - reading or test flashing with the ignition key in various positions. I finally got to a place where the Scan tool wouldn't read anything and the flash tests just failed.
    Disconnected the batteries and let it set. Reconnected and all seemed fine.
    So, tried one last time. This time I de-selected the option for a high speed link. Now a flash with the current tune in Test mode finally worked!
    So, I think I finally learned enough to be dangerous.
    I have a tune file to load. It's for use with a DSP5. Do I do a flash, or a complete program with OS?
    Truck is 2004.5 LLY that I bought new - so I know it has never been reprogrammed by anyone but my dealer.
    Jan 2020
    I pulled the fuse to my radio with aftermarket adapter so it's not on the bus, then did a slow speed load of OS and tuning file. It all worked perfectly. Thanks for the help!
    Quote Originally Posted by Loader. View Post
    I pulled the fuse to my radio with aftermarket adapter so it's not on the bus....
    These things always cause problems, you'll probably have to do this everytime you flash.
  1. Random lean spikes after letting off throttle
    By ferocity02 in forum Gen III V8 Specific
    Last Post: April 2nd, 2014, 04:22 AM
  2. help. stopped during flash locked ECM
    By SGFastMax in forum Duramax LB7
    Last Post: October 29th, 2010, 03:33 PM
  3. PCM Flash to Grand-AM Cup PCM
    By Rusty in forum Gen III V8 Specific
    Last Post: January 5th, 2009, 08:58 PM
  4. Knock when letting off throttle.
    Last Post: March 6th, 2005, 04:46 PM
