Page 33 of 36 FirstFirst ... 233132333435 ... LastLast
Results 321 to 330 of 357
Thread: E38 idle tuning
  1. #321
    Aug 2013
    Quote Originally Posted by nick123 View Post
    63 g/s in b1829
    Why did you do that?
  2. #322
    Senior Member Naf's Avatar
    Aug 2006
    Quote Originally Posted by statesman View Post
    He is followin the procedures written here, he is tryin to find his sweet spot for idle 1&2 without any interference from min airflow.
    He doesnt need to do this if he is runnin a mild cam. The min airflow just needed to be adjusted
    American Muscle, European Design, Japanese Tactics
  3. #323
    Aug 2013
    Naf, thanks for that explanation... but I was asking nick123 that question to see if he has any understanding of what he's doing or if he's just blindly following the procedure. Yeah, he probably doesn't need to do this with a mild cam but it's his choice.
  4. #324
    Jun 2014
    Yeah I'm planning on adding a cam shortly probably a rcr dragmaster. I understand maxing out min idle air B1829 will cause the ecm to disregard minimum idle limits essentially doing away with the lower hard limit.
  5. #325
    Jun 2014
    [QUOTE=nick123;252663]the closer I get to 550rpm using B1652 to reduce idle speed the rougher is seems to idle.
    I zeroed 1845 and 1843
    63 g/s in b1829
    First start after idle trim reset ....runaway idle to 1000rpm
    Used 1852 to bring idle down started with 1.1 went down to .75 still 630rpm
    Ran best at .8 702rpm
    Ok so I kept going
    .6 in B1652 680 rpm
    .5 and it hits target rpm right away dosen't slowly idle down while cutting timing... timing barely spiking above commanded
    .4 sputters adds allot of timing 32 deg
    .53 starts just over commanded rpm slowly idles down while cutting some timing then adds timing back after reaching 550rpm
    I drive around like this for a day added some timing 25 deg adds some rasp...idles around nice in parking lots and low speed cornering. Before with stock settings it would hang in 3rd and do a firm 3-2 downshift at about 25 to 30 kmhr super annoying...
    So the problem now is cold starting it at .53
    .53 sputters
    .6 a bit better but wont stay running
    .7 same here
    .8 stays running but throws code (cold start enrichment)
    .9 throws code
    1.0 no code
    This was all done cold and with B1829 maxed out and 1843 and 1845 zeroed.
    At 1.0 in B 1852 it idles at about 750 and pushing 8 to 9 per second
    I add the 1843 back and change 1845 increasing g/s in negative idle areas up to 0 at 0 and decrease g/s in positive idle areas.
  6. #326
    Aug 2013
    What mods have you already done?
  7. #327
    Jun 2014
    Kooks headers
    3inch exhaust
    Aem intake
    Solo mufflers
    Smaller harmonic balancer
    So I'm just reading this thread more and I'm confused do you set 1651 and 1652 back to factory after building the 1829 table out? I set up a map in v8...Click image for larger version.
  8. #328
    Jun 2014
    Kooks headers
    3inch exhaust
    Aem intake
    Solo mufflers
    So I'm just reading this thread more and I'm confused do you set 1651 and 1652 back to factory afterbuilding the 1829 table out? I set up a map in v8...Click image for larger version.
  9. #329
    Aug 2013
    Kooks headers
    Long tubes?
  10. #330
    Jun 2014
    Question
    Long tubes?
    No the ones that come with the hi flow cats
    Shorties 1 7/8 with 3inch collector
    And a 3.27 Camaro rear diff
    Do you put your B1651 and 1652 back to stock after tuning theB1829 table or...
    do you leave1651 and 1652 slightly above your target idle and let it learn down
  1. Idle/Idle Transition Tuning
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2007, 05:10 AM
  2. Idle Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 07:03 AM
  3. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    Last Post: July 11th, 2006, 03:58 PM
  4. Idle Tuning
    By 98WhiteDevil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 04:36 AM
  5. tuning idle
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 09:07 AM
Tags for this Thread
