Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: September 2021, V8.3.8 Public Release
  1. #21
    Jan 2010
    New Compressed (zipped) Folder.zip
    Lets see if this goes through.
  2. #22
    Jan 2010
    Strange. That shows up as different files.
    Is it possible something was corrupted on the PCM side?
  3. #23
    Quote Originally Posted by 1FastBrick View Post
    I'm not at my PC/laptop right now so I can't look at the files...
    are you saying that the file Second_Read.ctz is different than the .ctz that you flashed into the PCM...?
  4. #24
    Jan 2010
    Correct, The files are different.
    When I attempt to compare both files, I get the correct error showing they are different files. On both V8 and V7 software.
    The only thing that changed was I manually stopped mid flash and then did a recovery earlier in the day. Perhaps something was corrupted in the PCM and it was corrected when I did the recovery.
    Either way I am Grateful for the help I have received.
  5. #25
    Thanks for sending those test files and trace files. The files do show that everything flashed correctly and read back out correctly.
    Please let me know if the problem occurs again.
    Is the PCM a RoadRunner PCM by any chance?
  6. #26
    Jan 2010
    No it is not. Just a Spare PCM for my personal Vehicle.
    I was told the 1MB PCM's do not function correctly with the road runner and they discontinued support. IT only appears to work for the 512Kb 99-02 style pcm's. I have never had the chance to play with a roadrunner PCM.
  7. #27
    Update 1 has been released here: https://forum.efilive.com/showthread...Public-Release
    See the "What's New" for changes and updates.
  1. September 2021, V8.3.8 RC2
    Last Post: September 22nd, 2021, 01:38 PM
  2. September 2021, V8.3.8 RC1
    Last Post: September 20th, 2021, 09:29 AM
  3. June 2021, V8.3.7 Public Release
    Last Post: August 6th, 2021, 02:58 AM
  4. May 2021, V8.3.6 Public Release - Update 1
    Last Post: May 27th, 2021, 06:10 PM
  5. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
