Page 35 of 36 FirstFirst ... 2533343536 LastLast
Results 341 to 350 of 355
Thread: Custom OS#5
  1. #341
    May 2007
    I have all those and also selected Volumetric Efficiency for v8 just in case.
    My biggest problem with this system is figuring out what pids are needed for each map . Is there some way to find that ? A tutorial on that?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  2. #342
    Apr 2009
    For COS5 it tells you to ground PIN 56 on the RED Connector of the RED/BLUE ECU. What is the PIN on the GREEN/BLUE ECU ? Is it the same ? PIN 56 ?
  3. #343
    Quote Originally Posted by ne0c0de View Post
    COS5 is not available on 1MB PCMs that use green/blue connectors, only 512kb ones that use red/blue.
  4. #344
    Apr 2009
    Thanks Erik
  5. #345
    COS5 is only available for OS 12212156 which runs on 0411 PCM.
  6. #346
    Oct 2007
    V4 was going to be the N20 options only, but in the end it was possible to squeeze everything in to one O.S, though, on the later 2004+ O.S's this might not be possible. There is a few cars in Aus running O.S #4, it's been out for a long time, but these were only used by workshops for N2O cars only.
    I had to a custom O.S #3 for a 2006 Hummer and that was pretty much full up so I am not sure how far we can go!.
    Besides, nearly all 2003+ O.S' are used on ETC applications, I am not sure the TPS VE table would work too well on them.
    I am looking at using N20 on a VZ is there anywhere I can access the custom operating system 04 so I can control the Nos?
  7. #347
    Jul 2003
    hmmmm
  8. #348
    hmmmm
    It is also available for Holden OS 12225074.
    And it runs on various PCM's that are compatible with either of those OS's (12225074, 12212156).
  9. #349
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    I used Cos5 on my 2001 Camaro.
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  10. #350
    Quote Originally Posted by BowlingSS View Post
    I did same on my 2001 TA...
    I changed OS from 12202088 (2001 F-car) to 12212156 (2002 F-car), and then upgraded to COS5.
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
