Results 1 to 8 of 8
Thread: 4L60 to 4L80 2002 Silverado 5.3 DBW 12212156
    Default 4L60 to 4L80 2002 Silverado 5.3 DBW 12212156
    I have silverado, with the trans swapped to 4l80, the wiring has an adapter harness, doing research and searching these posts,
    Question what is a segment swap? is it copying a section of binary information from one file to the other? how is it done?
    is there a bin file that i can reflash this LS1B pcm with to run the 4L80 DBW 5.3L and 4l80 as if it was stock?
    thanks in advance
    Mark
    Mark
    So you open your stock tune. Then do a comparison (CTRL + F11) of a OS with a 4L80.
    Then click Edit, Copy Entire Segment, Transmission Calibration.
    Then Click Edit, Copy Entire Segment, Transmission Diagnostic.
    If you need a 4l80 tune i can send you one. Or i can do a segment swap if you need that.
    Thanks figured it out last night, had one problem with the speedometer being way off though, re calibrated it seemed like the numbers were very strange, but seemed to work
    Mark
    cool.
    Glad you have it figured out. What numbers were off when the speedometer was off?
    Nov 2022
    Just purchased a used Flashscan V2 and need help to finish my 2002 5.3 Silverado 4l60e to 4l80e swap. Using swap harness from Amazon that included 2wire pcm pigtail harness. Very new to tuning. Want to learn and share.
    Look at Post 2.
    If you cant figure it out just post your tune.
    Nov 2022
    Quote Originally Posted by nonnieselman View Post
    Look at Post 2.
    I will attempt to pull the stock tune soon. Still working on the frame resto. Once the bed is back on then I will try to figure out what exactly the "Segment" is. Still so new to the terms as well. I appreciate your response too.
    Quote Originally Posted by BigRed4x4GMFan View Post
    Post your tune if your having problems.
  1. Running Strange, 4.8L/DBW/1MB/4L80/12592433 OS
    By RADustin in forum Gen III V8 Specific
    Last Post: February 16th, 2017, 04:34 PM
  2. engine wont start on 4l80 tune, runs on 4l60
    By BagD72Chevy in forum Gen III V8 Specific
    Last Post: June 2nd, 2016, 10:49 AM
  3. 4l60-4l80 transmission setting changes needed?
    By 05gmcsierra in forum Gen III V8 Specific
    Last Post: September 10th, 2012, 02:14 PM
  4. 2009 Silverado 4.3l/4l60 to a 6.2/4l80 engine/trans swap = ABS lite
    By mowton in forum Conversions / Aftermarket Parts
    Last Post: May 13th, 2012, 04:38 AM
  5. Looking for a .tun file 2002 Silverado 6.0 LQ4, 4L80E, 4x4 with a 12212156 OS
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2010, 07:54 PM
