Results 1 to 2 of 2
Thread: E39 SRX 3.0 Idle adjust
    Default E39 SRX 3.0 Idle adjust
    Trying to idle up a 3.0L with no luck.
    It will idle at target in gear but not in park. it ignores the desired idle speeds.
    any ideas?
    Here is the factory tune E39_0000
    I made changes and tried E39_0001
    i was grasping for straws after 3 hours of fooling with this so i started adding to the Torque response Commanded power tables and the Torque models. It either idled at 550 rpms when targeting 750 in P/N or it would go to 3000 rpms. Nothing inbetween.
  1. *** Looking for a 2014 Cadillac SRX stock file? ***
    By vetteboy2k in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 24th, 2014, 12:10 PM
  2. Replies: 0
    Last Post: October 5th, 2013, 08:36 AM
  3. Cadillac SRX 2011 Script file not supported
    By sportone in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 21st, 2011, 10:04 AM
  4. need stock tune 2011 srx or 2010 srx
    By redonetoo in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 9th, 2011, 06:03 AM
  5. How to Adjust LBZ Idle Speed?
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 8th, 2007, 04:27 AM
