Results 1 to 10 of 11
Thread: LBZ - Rescaling MAP Sensor in EFI Live
    Mar 2023
    Question LBZ - Rescaling MAP Sensor in EFI Live
    In the middle of "adjusting" an LBZ truck with a larger VGT for sled pulling. The log files show the MAP sensor is maxing out at 39.01psi (NOT including barometer pressure). I was talking to the owner and we were thinking of installing a 5 bar MAP sensor, 0-5V, adapted so it could be read through the factory harness. I have seen in other forum post (https://www.duramaxdiesels.com/forum...scaling.71271/) where .cax (or .cax8) files were added to enable rescale the MAP sensor, but none done for the LBZ. I know on the LLY's you can adjust the B0202 easily for this, but that table was remapped for altitude in the LBZ. Truck is currently running the 52604138 OS.
    Any thoughts?
    svvag200
    Guest
    principle is same
    but unfortunately efilive does not offer a pressure sensor linearization map
    and in LLY control unit dump adress different
    Member koolky's Avatar
    Aug 2013
    [B3499]
    ; Description
    DESC.001 = MAP Sensor Scaling
    DESC.002 =
    DESC.003 = This is used for aftermarket Manifold Absolute Pressure sensors that have a
    DESC.004 = different range than the stock sensor. With the right sensor, it allows logging
    DESC.005 = higher boost values than the stock sensor could handle.
    ; Seg Caption Major Minor Vis Dis 2d Grp
    VIEW = 2 "MAP Sensor Scaling" "Engine Sensors" "" 1 2 0 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1B6DEE 0 16 SNM 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = kPa 0.1 0 2 0 3276.7 0 3276.7
    IM_SLOT = PSI 0.014503768 0 2 0 475.2 0 475
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = kPa "kPa"
    IM_COL = PSI "PSI"
    SI_ROW = mV "156.4,5000"
    IM_ROW = mV "156.4,5000"
    May 2020
    Hello, I am wondering if this is normal readout for the factory sensor scaling. It seems off to me.Click image for larger version.
Name:	Sensor Scaling.PNG
    Jun 2022
    Quote Originally Posted by THAHN View Post
    Stock sensor should read 366 Kpa at 5000mv. Yes its wrong.
    2016 LML
    May 2020
    Thank you. That is what I thought. I used the same CAX file as shown. Any idea how to get the correct readings?
    Jun 2022
    I tried it on a stock LBZ file I had and got the same numbers. The factors look good. I would suspect its a bad address. Maybe scaling for the Baro Sensor?
    2016 LML
    May 2020
    Thank you for the help. If the address isn't correct do you happen to know the correct one? Otherwise does anybody else know what that address might be? Thanks
    Jun 2022
    Going to need a Bin and a “treasure map” to find the correct address. Unfortunately I do not have those.
    2016 LML
    May 2020
    I figured it would come down to needing that. If anyone out there could lend a helping hand it would be appreciated. Thank you
  1. LBZ BP sensor vs MAP sensor readings
    By Don Z in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 20th, 2017, 01:52 AM
  2. Map sensor problem in efi live scan tool
    By zayne0 in forum Petrol / Gas
    Last Post: October 23rd, 2014, 12:17 AM
  3. rescaling map sensor
    By BAD BOB in forum FlashScan V2
    Last Post: May 16th, 2011, 02:42 PM
  4. EFI Live LBZ Questions
    By coldLBZ in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 22nd, 2007, 07:55 AM
Tags for this Thread
