Results 11 to 20 of 22
Thread: Adjust for tire size
    Dec 2006
    Awesome, thanks. Scarab, I am pretty sure the it will work for the Blazers too.
    8.7 @ 84 (1/8 mile) bolt-ons
    Quote Originally Posted by ScarabEpic22
    And the LL8s too???
    Yes, finally.
    Yes, finally.
    YES!!!!
    Finally, this is going to make it a breeze for me to swap to a set of 20s here in the spring when I buy them!!
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    An all new speedo calculator is included in the next release. It should be available (pre-release) this week.
    Thank You!!
    Dec 2006
    Will you post the link here when the update is ready? Will we only have to update the EFILive software? I just want to make sure I'm ready to start using it the day it comes out.
    Dec 2006
    Nearly done - just adding support for a few weird anomolies with the way some PCMs calculate speed.
    Who knew GM had sooooo many different ways to determine the speeds of the varous drive shafts, axles, diffs, chains, sprockets, gears and tires.
    Dec 2006
    We really appreciate yor work, can't wait to try it!
  9. #19
    Oct 2005
    I recently shortened my driveshaft, is there a correction factor in the LLY ECM to change?
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  10. #20
    Oct 2005
    Just tried the new calculator....very nice!
    BUT when entering values by hand (not picking from the list) the circumference does not update.
    In my case I needed to enter 325 for width which is not available in the drop down menu. The update button to the right is grayed out also.....You might want to expand the table to 365 as these are widths found on HD trucks!
    Update: This issue seems to be intermittent as it does work sometimes....
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. changed tire size, now ABS INOP
    By gcross in forum Gen III V8 Specific
    Last Post: November 11th, 2009, 04:18 PM
  3. help changing tire size!!!!
    By 2007silverado in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2008, 06:21 AM
  4. tire size and tune settings
    By brobradh77 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2008, 11:40 AM
  5. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
