Originally Posted by
87gmc
so on SSpdDmon you can just replace the stock sensor with wb? I mean the pcm will still see it as a narrow band and the you can log on efilive as wide? Just got my lc-1 and ready to experiment
Check out this screen shot of the narrow band simulation from a wide band sensor:
http://www.efilive.com/ss/w02_wot.gif
WO2 AFR = wide band
O2 SIM V = narrow band simulation.
In the bottom chart, the O2 sim is logged next to the actual factory narrow band so you can compare them side by side.
