Results 1 to 10 of 14
Thread: Fixing your Bricked V2
    Jul 2004
    Default Fixing your Bricked V2
    Som of you have bricked your V2 in the last few days and you're supposed to send it to me to fix. The first unit arrived today and since if found out what went wrong and didn't have the instructions to fix it the "right" way, I decided to try another way which surprisingly enough worked.
    You may laugh all you want, but there is a good chance it will work!
    You'll need a bath towel and a hot water bottle.
    Connect the USB cable to the Flashscan, but not to the computer yet. Fold the towel so it's just over twice the size of the hot water bottle and place the Flashscan keypad down on one side of the towel. Fill the hot water bottle with 170 degree water and place it on the Flashscan and fold the towel over it. Wait about 15 minutes, plug it in and try again. If it seems to work, make sure the water is still warm, wait another 2 minutes and try flashing the new boot block when Paul uploads it.
    I cheated as I have a stock of the do not remove warranty stickers. I opened it up and warmed it gently with a heat gun.
    Make sure the Flashscan gets warm, if not warm the water bottle back up.
    I know it seems absurd, but electronics run faster at higher temperatures and the problem is a race which can possibly be won at slightly elevated temperatures.
    There are limits to how hot you should get your Flashscan
    Ira
    Jul 2003
    Very Interesting
    Ira, that's very clever, shows a very deep understanding of electronics...
    Default wierd......
    Huh.... I always thought electronics worked faster when cool..... Maybe like denser molecules closer together....
    You learn something new every day!
    Chuck CoW
    Jul 2004
    Quote Originally Posted by Chuck CoW View Post
    They can be run faster when you keep them cool as they won't start glowing, but they will run faster when hot. The faster they run the hotter they get and you end up with a runaway thermal failure in extreme cases. which is why all the effort on keeping things cool. In this case, one piece has a crystal and runs at a constant speed and it was in a race with a part with an internal oscillator which when warmed up was able to win the race.
    Worked for me, no idea if it will work for anyone else. Conceptually I have the tools to actually fix them no matter what but Paul was busy ignoring me so I "had" to experiment.
    What I really want to know is if this works for anyone else. I'll have another unit tomorrow to try it on but I was hoping to avoid them all coming to me.
    Ira
    Senior Member Hyper99's Avatar
    Oct 2005
    Nice job Ira.....You have my respect
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
    Quote Originally Posted by Ira View Post
    Well Ira did tell me to try it and well, no I didn't try it.
    I was thinking along the same lines as Chuck though, I always thought stuff ran faster when its cold - but after Ira's cool (no pun intended) explanation, I now understand the relationship between over-clockers and jacked-up cooling systems.
    I'm suitably impressed.
    Senior Member SV8346's Avatar
    Nov 2007
    wish i had read this before sending mine back over to you paul, but its on its way now anyway. Would have still needed to come back over to you anyway to get the usb power input fixed.
    2016 RG Colorado 2.8TD
    Jul 2004
    Well, I've now repaired 3 of the bricked V2s. 2 of them came back to life with a bit of warmth, one with a heat gun and one resting on top of the espresso machine for 20 minutes. The third one required I do it the hard way. If you can flash the bootblock with a bit of warmth, you might still have to do it a second time again later. Took a couple of tries before the second one took and I had to put it into bootloader mode with the Ctrl key and flash everything a second time after having already flashed the new bootloader and firmware. Didn't need heat the second time but it did need the second attempt before it was right.
    Ira
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Do you think there are any risks from doing this? Overheating some of the pieces? Reducing the life of some components?
  1. Fixing 02 codes through tuning?
    By Zfreak in forum Gen III V8 Specific
    Last Post: December 18th, 2009, 05:01 AM
  2. Idle issues after fixing MAP sensor leak!!!
    By Darkness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 01:56 AM
