Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 88
Thread: BB Logging beta update: May 06, 2008
  1. #21
    Quote Originally Posted by Kevin Doe View Post
    Paul, I am unable to chnage the dropdown box from "*.wav" to "*.*" or "all files". The dropdown box only contains "Wave Files (*.wav)". I even tried manually adding the .wav extension to the file name. That didn't work either.
    Where you type in the filename is the default text "*.wav", change that text to *.* and all files will show up.
  2. #22
    Quote Originally Posted by lakingslayer View Post
    I guess I just needed to talk out loud about this. After the post I thought about it and realized I didn't re-format the internal memory. Then I re-installed the firmware update. It worked after that. One thing is I re-formatted both the SD card and internal memory but the config files were still there. I thought they should have gotten erased. Anyway thanks for listening.
    There are two internal memory file systems: "Config" and "Data".
    You can only format the "Data" filesys from FLashScan's menu.
    You can only format the "Config" filesys from EFILive_Explorer's [Config] tab page.
    On tab pages: Scan, Tune and Config, is a button called [Properties]. That shows you the space on each of the file systems.
    Note: Scan and Tune refer to the same file system (Data) and so will always be the same.
    We made the config file system non-formatable without a PC because there is no point formatting it unless you can replace the config files and that requires a PC. It just stops you accidentally erasing the config file system while out in the field. While still allowing you to format the data file system if required.
  3. #23
    Config space: formated from EE (under Config Files tab) as Paul said.
    Data space:
    - Internal: formated from V2 (first select internal option),
    - External: formated from V2 (first select SD option).
  4. #24
    LS1B_A connected to V2...
    On V2:
    - System readiness tests show readiness states, looks to be correct.
    - Mode 6 says "Mode $06 not retrieved" (or similar), I take it it's not there yet.
    Key off, no laptop: V2 detects 1 PCM.
    Key off, laptop: V2 detects 2 PCM's (but there's only 1 PCM).
    BTW: in system readiness tests, what is CCM (is this EVAP)...?
  5. #25
    Jan 2004
    I think I might have the same problem as before with BBL cutting off early with my E38. Morning trip was about 40 minutes and only got 5 minutes of logged data. Afternoon trip was probably 60 minutes and only got about 20 minutes of data.
    I will investigate a little further tomorrow morning and post up more details. I wasn't thinking this morning/afternoon and did not get a trace file.
  6. #26
    On V2:
    Not implemented for VPW vehicles yet - only CAN so far.
    I have seen that and am trying to fix it...
    MIS "Misfire Monitoring"
    FUEL "Fuel System Monitoring"
    CCM "Comprehensive Component Monitoring"
    CAT "Catalyst"
    HCAT "Heated Catalyst"
    EVAP "Evaporative Purge System"
    AIR "Secondary Air System"
    ACRF "A/C System Refrigerant"
    O2S "Oxygen Sensor"
    HTR "Oxygen sensor Heater"
    EGR "EGR System"
    CCM: is a "catch all" for electronic systems not covered by the other 10 tests that can affect emissions. On most vehicles I've seen it is either not supported or always ready.
  7. #27
    May 2008
    Would it be possible to save active DTCs for a vehicle on the SD/internal memory?
  8. #28
    Quote Originally Posted by nevinsb View Post
    Yes, try this:
    F2 Scan Tool -> F2 Diagnostics -> F4 Record All Diags.
    That will create a text file called DTCxxxxx that you can copy to your PC and open/view with Notepad.
  9. #29
    swingtan
    Guest
    Quote Originally Posted by XLR8NSS View Post
    X2.
    I have a few logs that seem to just end mid stream.
    I've also had times when the V2 will log fine, then other times it appears to go into "pause" mode ( left hand green LED flashing slowly ) but you can't take it out of pause mode. Sometimes the displayed data also seems to freeze when this occurs, but not always. Pressing the <cancel> key will terminate the logging session and save the file. When I check the log files in ScanTool, the file is only 2KB in size and only the meta-data appears in the log.
    Simon.
  10. #30
    Can you email me the log files at [email protected] and include a link to this thread, thanks.
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
