Thread: VSS v RPM HELP
    Jan 2007
    Question VSS v RPM HELP
    4L60E SHIFTING @6200RPM WOT only in D, has shift kit TM & shift speed zeroed out to cancel adaptive learning.
    upshifts set at 1-2 @31mph 2-3 @63mph 3-4@115mph
    3.73 gears.
    Race only car so 3-4 not used
    have searched and looked at other tunes on Holden crazy.Nothing close.
    question is (at last),
    How do I work out the optimum shift MPH for 6200 revs? is there a formula using A4 ratios v rear gears v rpm. before I get to the track for reasons below.
    The only log I have secretly managed( No computers in our race class) showed 1-2 shift 39mph@5679rpm??, 2-3 shift 80mph@6017. This was with shift points at 6000rpm Trap speed was 12.3@111mph at 5606 revs.
    Any help would be appreciated
    thanks
    Al
    I presume you're only interested in wide open throttle shifting at this stage?
    If so, look at the Transmission calibration -> Shift at RPM -> Upshift values. You can specify at what RPM to initiate the shift.
    If you want to work out what vehicle speed corresponds to what engine RPM in each gear, open one of the part throttle shift tables and click in a cell. The RPMs are displayed in the status bar at the bottom of the window. The values are calculated for each gear based on the calibrated gear ratios and diff ratio.
    Al,
    Shift at the highest RPM your valvetrain and transmission can safely handle.
    For the WOT shifts to trigger, the WOT MPH and WOT RPM both have to be met...
    so set one a little lower, and make adjustments on the other until it shifts where you want.
    Joe
    "Shift at the highest RPM your valvetrain and transmission can safely handle."
    And if you know your peak power RPMs, shift 200 rpms above that, given what Joe said.
    The attachment is a chart for 3.73 gear shift points vs mph.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Jan 2007
    Cheers everyone,.
    I take it I only need to adjust the WOT tables for mph not the part throttle tables aswell as the only time its at part throttle is in the pits before and after a run
    Al
    Jan 2007
    Quote Originally Posted by jfpilla View Post
    Thanks for file but for some reason my L/top says I don't have enough memory to open it even with everything else shut down?
    I will email it home and try it there tonight
