Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 88
Thread: BB Logging beta update: May 06, 2008
  1. #71
    Jul 2007
    Try reading the PID description files in
    EFILive\V8\EFILive_Hapi\Pid Descriptions
    These files list all the supported PIDs and their descriptions for each controller. All you need to do is select the required PID's and enter them correctly into the options.ini file, then copy the options.ini file to the V2 unit.
    For example, to log O2 sensor voltages in the E38, add these lines...
    ECM, O2S11V
    ECM, O2S21V
    Remember to watch your channel count when adding additional PIDs.
    Simon.
    Got it fixed up. Just ran a 1 hour test of scanning w/bb. Thanks.
    07 Silverado DMax Classic
  2. #72
    Cool... "I love it when a plan comes together..."
  3. #73
    Jul 2007
    by thew way, I used your options file and modfied to taste for my car...
    whats the best way to retrieve data? Use an SD card and the explorer to read it back??
  4. #74
    Quote Originally Posted by 02Z06 View Post
    I just re-configured the V2 with the AFRATIO_M Pid and it still says de-select this Pid.
    Are you sure, you've copied the latest *.pmm files from the downloaded/extracted zip file to the [Config] tab page in EFILive_Explorer?
  5. #75
    Not sure if anyone has mentioned it, but if I clear DTCs on my LLY, I get an Error $0281 again.
    After deleting codes, can you save the trace file and email it to me at [email protected]. The trace file option is in the scan tool options menu on FlashScan.
  6. #76
    Oct 2003
    This is the file I used: http://download2.efilive.com/Softwar...ay_06_2008.zip
    Jim
    08 Z06
  7. #77
    Quote Originally Posted by thunder550 View Post
    Deleted it and still getting the same error.
    Exit from all EFILive software.
    1. Run regedit
    On XP click start->Run, enter regedit and click ok.
    On Vista, click start, enter regedit into the search box (just above the start button) and click on the regedit link that appears.
    2. Locate the key
    \\HKEY_CURRENT_USER\Software\EFILive\V7\Properties \Dir
    or
    \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Dir
    depending on whether you are running V7.4 or V7.5
    3. Delete the Dir key and all its subkeys.
    4. Restart the scan tool.
    Deleting that key will clear all "known" EFILive folder locations. The next time EFILive is started it will figure out the correct folder names - assuming the software is installed correctly.
    If that does not work, uninstall the software, delete the registry key:
    \\HKEY_CURRENT_USER\Software\EFILive\V7.5 (or V7)
    That will reset ALL EFILive's settings.
    Note: uninstalling and re-installing the software does not reset the registry information. That is why I suggested doing it manually.
  8. #78
    Quote Originally Posted by TFZ_Z06 View Post
    Yes, that's good.
    It is even faster if your PC has a card reader and you plug the SD card into your PC and extract the files that way just using Windows Explorer (instead of EFILive_Explorer).
  9. #79
    Oct 2003
    Just double- checked the .pmm files. The Config. tab page shows they were all created 5-03-08 @ 8:57PM. I assume these are the latest?
    08 Z06
  10. #80
    That's exactly what I do...
    I log to the SD card and I read it back with EE...
    I have multiple laptops/PCs so I only delete the log files from V2 when I know all laptops/PCs are sync'd up.
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
