For reference, my AutoCal beta unit arrived with no cables- not a problem because you can borrow the necessary cables from a V2. Not knowing what to expect, I plugged AC into a vehicle and received a "No PIDS" selected message, whereupon I plugged it into my laptop to download some PIDs. Tried to down load them and received a 0182 error code. So I used EFILive Explorer to format the "Config" area of AC memory and then I downloaded the Options file along with the pmm files I plan to use. (Same files as I use in V2.) Plugged AC back into a vehicle and selected "Display Data" and everything worked fine. Then I tried to log data and received a 0185 error. Next I plugged AC back into my laptop, selected the "Scan Files" tab and got another 0182 error. I couldn't find any way to format Scan Files memory with EFILive Explorer so I started snooping around AC and found a "Format File Sys" option. (After plugging AC in, scroll down to "AutoCal Options", select it, then scroll down to "Format File Sys".) Everything appears to be working properly now.
Update- Dragged the log file from AC into my laptop. The file opened fine and displayed data accurately. Suggestion: Make the default file name other than BBL (ACBBL perhaps) to avoid file name conflicts between V2 and AC data logs.
