What about a lift pump, are you doing boosted launches in 4x4? You will need sleeves for the tie rods, pitman & idler braces, front end let down so the cv's are close to being strait, clamp the rear springs, these are things you will need to do a good hard boosted launch. How big of tires are you running?
