Results 1 to 8 of 8
Thread: fjo serial cable questions..please help
    Mar 2007
    Default fjo serial cable questions..please help
    has any one made a serial cable for the fjo wb to connect to the v2 yet? thx.
    Post pictures of your FJO showing the serial port on it...
    If it has a DB9 connector, then all you will need is a DB9 cable and the null-modem adapter.
    Mar 2007
    it does not have a connector just wires. this is what the manual says" This will require that your PC have a serial port or USB/serial adapter. To install the black PC serial cable, connect the red wire from the PC cable to the white/green wire of the controller. Now connect the brown wire from the PC cable to the white/red wire of the controller. Finally, connect the black wire from the PC cable to a good ground point. The PC cable can now be connected to the serial port of your PC.
    Which PC serial cable...?
    If you can identify Tx, Rx, and Gnd it is very simple to make a cable.
    Mar 2007
    the manual i have is this one it dosent say tx or rx? i cant upload yhe manual it too big to attach but i downloaded off of fjo.com
    Nov 2006
    MAKE SURE WITH FJO
    it seems the white/green wire is TX and, the white/red wire is RX.
    RJ12
    1 = Tx Data
    2 = Rx Data
    5 = Ground
    LC-1 WBO2
    Mar 2007
    fjo support said it would not work with serial only analog so im buying a new wideband. any suggestions?
    Nov 2006
    Lc-1
    LC-1 WBO2
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 10:36 AM
  2. serial port cable that goes to v2
    By articSS in forum FlashScan V2
    Last Post: August 19th, 2014, 12:57 PM
  3. Serial V2 questions
    By Slowrc in forum General
    Last Post: January 23rd, 2010, 11:42 AM
  4. FlashScan to LC-1 Serial Cable Diagram
    Last Post: November 26th, 2009, 07:50 AM
  5. Tried making own Serial Wideband Cable, HELP!!
    By edwardzracing in forum FlashScan V2
    Last Post: March 18th, 2009, 04:54 AM
