Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: help kr* problem
    Mar 2008
    Default help kr* problem
    im having some knock retard issues,things i allready done logged the pid for the o2s and above 50% tp im seeing 950mv on both banks.i also put 1 gallon of 114 octane on less than a quarter tank,fixed dip stick cause it was hitting the header,tighten some losse brackets in engine bay and re enforced exhaust and im still seeing from 5-8 kr*.it dosent do it all the time it seems to do it when it bangs into gears,some times i could take it from a dead stop and lean into the pedal to about 100mph wot and i wont get any retard but if im crussing at about 30 mph and a go wot it will down shift and i get knock confused.gif at wot im seeing about 10.7-11.4 AFR and only changes that were made were build trans and pi vigilante 2600 stall 10.5 multi disk.......anything else i should check before i try adjusting the knock sensors?
    i got a 2006 ss silverado my mods are volant cai with ram air tube, magnaflow custom exhaust, dmh ecutouts, LT headers, cat delete, 8.5 msd wires, csr catch can, tb coolant bypass, magnacharger crank pinning kit, 160 stat, fully built 4l65e, transgo-hd2 shift kit, pi vigilante 10.5 triple disk 2600 stall, justin tune, tru cool trans cooler, radix mp112, 2.8 pulley, bigger heat exchanger, joe gibs carbon fiber cover, custom delfi 60lb injectors, (2) 100 mm pulleys, efilive v2, gatoback belt, phantom2 boost & vac gage, aem wideband
    Hi BBSS, welcome to the forum...
    Did KR just start showing up...?
    Is it audible (might be hard to hear over exhaust)...?
    If real knock just started showing up, there may be several things to consider:
    - carbon deposits: run top engine cleaner thru (I don't know to do it with a boost adder);
    - check spark plugs for gap too big;
    - check MAF is reading good, clean it;
    - check other sensors are good (IAT, ECT);
    - check the knock sensors are good;
    Post some logs and your tune file (if you can).
    Mar 2008
    could you give me your email adress so you could try posting my logs and tune.i tried to post them but dont know how
    Jul 2008
    Email them to [email protected] and I will post them for you.
    Yes, you can email the files to either of us (I replied to your pm before seeing the previous 2 posts... ls1vt209 beat me to it...)
    To post files in a thread:
    - type in your reply text,
    - press Go Advanced,
    - press Manage Attachments (scroll down to see this button), this causes the attachments window to pop up,
    - in the pop up window, press Browse and locate/select the file you want to attach, click OK,
    - in the pop up press Upload, wait for it to finish uploading/attaching,
    - close the pop up window,
    - finish typing your reply,
    - submit your reply.
    Jul 2008
    As requested. Sorry haven't had a chance to have a look for you.
    test kr 001.efi
    log correct pid afr.efi
    newtune for trans0003.tun
    Mar 2008
    Quote Originally Posted by ls1vt209 View Post
    test kr 001.efi
    this log was done right before my new trans and pi vig.it was at the track with no knock
    Mar 2008
    anybody
    I'll be able to view those 4 files in more detail later tonite or tomorrow (I'm on my Mac right now).
    BBSS,
    This is not be the problem, but do set the out-of-range tables to in-range values (use max-1 or min+1) and save the file:
    Quote Originally Posted by tunetool
    Out of Range calibration summary: 10:14:13 am, Saturday Feb 07, 2009
    Engine Calibration.Abuse Management
    {B1207} Abuse Management Vehicle Speed Threshold, was out of range when loaded.
    Transmission Calibration.Trans Pressures
    {D0701} Base Pressure 1->2 Shift, contained one or more out of range values when loaded.
    {D0702} Base Pressure 2->3 Shift, contained one or more out of range values when loaded.
    {D0703} Base Pressure 3->4 Shift, contained one or more out of range values when loaded.
    Last edited by joecar; February 7th, 2009 at 08:29 AM. Reason: Corrected my - + typo... :^)
  1. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
