Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: LC1 AFR output numbers
    Dec 2005
    Default LC1 AFR output numbers
    I installed version 7.5 and now my AFR map does not display AFR, it diplays the voltage output I think.
    How do I get this straight?
    Thanks,
    Glenn
    Glenn,
    Do you have FlashScan V1 or V2...?
    If you have V2, read this:
    Are you using analog AFR (connected via orange block) or serial AFR (connected via RJ12)...?
    Either way, on the V2 LCD/keypad navigate to Options->Setup->Edit Settings, and then do this:
    - if you're using analog AFR, set/enable the following parameters:
    A/D PIDs
    - if you're using serial AFR, set/enable the following parameters:
    Ser PIDs
    COM In
    WO2 Type
    WO2 fmt
    WO2 Data
    If your V2 LCD menu does not have those options, then you will have to update the bootblock/firmware also (i.e. install V8 and then carefully read and understand the upgrade/update document, do not proceed until you are clear on what is about to happen):
    Updating FlashScan V2 Firmware:
    showthread.php?t=9375 posts #9 and #10
    showthread.php?t=10014
    Dec 2005
    Thanks for the help, but I have V1
    Glenn
    Oh, with a V1 you should just select the AFR_LC11 and BEN_LC11 pids.
    In your AFR and BEN maps, edit the map properties: on the Data tab set AFR_LC11 as the data.
    You may have to validate pids first.
    Dec 2005
    Joe,
    Everything you asked is done. I transferred everything over from 7.3 and the data tabs in my map properties are correct.
    When I am in F9, the data page in the scanner, I can see the AFR and it corresponds pretty well with when my LC1 gauge is putting out.
    However, when I hit F11 to watch my maps, the AFR map is not showing AFR, but anywhere from 1.1 to 7.0 give or take.
    The only thing different about my maps in 7.5 from 7.3 is that my BEN map is no longer in map A, it is in map C and my AFR is in map B. My cylinder air is in map A.
    Would this be the problem?
    I will go try it anyways.
    Thanks,
    glenn
    Nov 2006
    map properties> data> parameter> AFR_LC11
    LC-1 WBO2
    Dec 2005
    I am stumped, I have done everything that you guys have suggested and I am still having a problem??
    Glenn
    Nov 2006
    Post up a log.
    LC-1 WBO2
    Also post some screenshots.
    Dec 2005
    I just realized that my dash board is in Kilometers and C.
    Maybe this is the problem. I am searching how to change it.
    Glenn
  1. Massive log numbers???
    Last Post: May 8th, 2008, 10:35 AM
  2. FTC Numbers
    By white2000ta in forum General
    Last Post: January 8th, 2008, 05:19 AM
  3. Tried to AutoVE and only got 50,55, 60 MAP numbers
    By 99ss in forum Gen III V8 Specific
    Last Post: September 13th, 2007, 03:06 AM
  4. base numbers
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2006, 03:10 PM
  5. Table Numbers
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2006, 08:21 AM
