Page 21 of 26 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 253
Thread: Flashscan data logging..
  1. #201
    Quote Originally Posted by waterbug1999 View Post
    So how do you tell what is what?? Im getting ready to go back to the old shit.
    I highly recommend waiting a few more hours until I post the updated version8 software.
  2. #202
  3. #203
    Jul 2007
    WILL USE TODAY!
    07 Silverado DMax Classic
  4. #204
    Jody, use the new one... see post #202.
    You will have to update the V2 firmware, use EFILive Explorer to do so.
  5. #205
    Its not strictly necessary, but if you do uninstall and delete the two folders, then your new V8 install will be cleaner and ther ewill be no "old" files hanging around to confuse you later...
    On XP:
    \Program Files\EFILive\V8
    \Documents and Settings\All Users\Application Data\EFILive\V8
    On Vista (you may need to set "show hidden files" to see ProgramData)
    \ProgramData\EFILive\V8
  6. #206
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    so, am i suppose to delete everything?? This is getting really confusing.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  7. #207
    Mar 2008
    I went ahead and downloaded anyway.. Now, I went to EE and its different so I assume its good.
  8. #208
    Sep 2007
    Forgive me if this has been brought up already but... Is there a way to switch the PIDS to imperial?
    I've already selected 'custom' from the display menu of f3 "display" tab.
  9. #209
    Sep 2007
    Jeez - I put that in the wrong spot - Sorry guys.
  10. #210
    Jody,
    Have you figured out how to use it...?
    Did you program V2 with firmware 2.06.07 using the old EFILive Explorer...?
    Then, on the Scan & Tune display (your post #207 above) follow this:
    Hints:
    - On "LLY Manual" rightclick->Properties and change its name to "LS1" "Trims" (for example), and select the LS1B_A controller;
    - Uncheck the other names and click the red minus button to delete them;
    - Click on PID Name to sort by pid name,
    - Select some pids, click on the double left arrow button to add them;
    - Watch the pid channel counter below (if it turn red you have too many pid channels);
    - Click the up and down arrows to arrange the V2 display order of the selected pids;
    Rightclick on the next empty controller slot and name/create another pid list (e.g. "LS1B" "Trans")...
    FInally, click on Save , and then click on Program (V2 has to be connected to PC).
    Remove V2 from PC... you're now ready to log
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
