I've done a little bit of testing over the last couple of days as we drive to QLD from Melbourne. I've seen a couple of funny things happen that may not be a real test, as I'm logging the T42 in a V6 Sportswagon.
  1. If you connect the V2, then turn on the ignition, you get error chimes and alerts on the dash to say that ESP and ABS are disabled. This is very much like the early days with BBL and the E38. however, just to complicates things...
    • If you connect the V2 after the car is running, there are no errors and ESP and ABS are fine.
    • Laptop logging does not cause the errors either.
  2. When completing a BBL session by pressing the <Cancel> button, the V2 indicates that the file is saved and then appears to hang. Previously it would drop back to the main menu but now it sits at the screen showing the file number. If I then press<Cancel> or <OK> the V2 saves a trace file and appears to hang at the trace file name just like the log file. Pressing <Cancel> or <OK> again returns to the main menu.
    I'm not sure if this was a diagnostic mode that was left in or not.
If you want me to upload a log and a trace, let me know.
Simon.
