Do you get those same vertical white lines in the log files?
In the morning, I'm burned out tonight. Thanks for continuing to work with me.
I did notice something strange. I created my own ken dashboard, opened my log file with that. Had it working very well. Deliberately saved the log file because somebody said it would then remember to use the ken dashboard and ken pid's. It still grabs the default stuff, even if I preload my ken stuff first, of reloads the default stuff. Thought I would be golden with this log once I got it working once. Guess not.
2001 Corvette Z06
OK guys, was shutting the notebook down to go to bed and got this little nasty notice from Vista. Ok, sucked into staying up a bit more. Sure, I'll play and clicked on the button to let Vista do whatever it wanted to do. So it reinstalled with its "Recommended Setting" whatever the heck those are??? Ran the program and the samples now work again.
I'll try my stuff again tomorrow.
It looks like the Vista Ultimate OS may be causing problems. Do you guys even know why Vista prompted me like that? And who knows what its recommended settings were that worked, or the ones that didn't work in the first place??????
here's the screen shot of the message.
2001 Corvette Z06
Something interrupted or messed with the install or altered settings, files or configuration values in the EFILive installation. It may be a virus, it may be some other badly behaving application on your system interfering with the EFILive files.
Can you send me one of the *.efi files that displays the white vertical lines.
I can check to see if its been modified in any way. Maybe it has had a virus payload inserted into it.
Morning guys, I'm fresh now.
OK, all this virus talk got me to do my periodic maintenance. I've always got mcafee running, but still stuff gets in.
msconfig tells you about all your tray crap. Removed a bunch of stuff there including you 7.5 and 8.0 auto updaters.
Went thru control panel, uninstall. If you don't use it, lose it!
Ran Malwarbites Anti-Malware, great program. found a few reg keys it didn't like and blasted them.
rebooted clean, ran scan tool and opened Manaro 0 to 100 sample file. Looks great, able to run and chart!
Without changing any defaults, opened my file. No go, datatab shows 2 externals and that power_rw that I last was playing with. Missing rpm, tp, vss, aft, etc.
Here's the interesting piece, making no changes, went back and reopened the manaro 0 - 100 sample that just looked good a minute ago, and now it is scrambled with verticle lines.
Pic and both the manaro and my efi files attached for you viewing pleasure
BTW, I've got a virgin BBL log file in my flashscan that I could copy over and try, but I'll wait for your instructions before I do anything. I could reinstall and overwrite registry keys too, but with this new sequence I've shared, I'll just wait for you guys.
Ken . . .
What is the file you refer to as "my file"? Can you send that to me as well?
Either attach it here or send to [email protected]
It is certainly a strange problem.
Can you try turning off Vista's UAC (User Access Control)? Then re-install EFILive and try running the software again with UAC still turned off?
