EFILive FlashScan Serial Protocol .pdf reads:
Power up FlashScan, and select the following option:
1. F4 Options -> F1 Setup -> F1 Edit Settings.
then
2. Scroll down to the COM Port setting using the down arrow key.
3. Change the value to Dyno using the left or right arrow key.
4. Press Ok to save the changes.
When I select F4:F1 Setup:F1 Edit Settings, my choices are:
"Unknown"
"Wide-O2"
"External"
No setting called "Dyno" is available.
What should I do?
