Results 1 to 10 of 11
Thread: Motec PLM Serial Data to V2
    Sep 2006
    Default Motec PLM Serial Data to V2
    Just enquiring whether it is possible to add the Motec PLM to the list of serial devices for V2.
    I have attached the PLM user manual which should have all info required for RS232 data ....
    Kyle
    Sep 2006
    I know its any old thread ....any chance of this happening Paul?
    Paul is on a break for a week, hopefully it won't be 2 years before you get an update
    Somehow I didn't see this thread two years ago...
    [ please bump the thread if you don't see a response after a few weeks ]
    I don't see any reason why it can't be done. What would help is if you could hook up the wide band controller described in the pdf document to FlashScan's serial interface.
    Then set up FlashScan to use either the AEM or Zt2 wide band controllers. Use only those two settings because they match the same baud rate as the one specified in the pdf. (i.e. 9600 8,n,1)
    Make sure the Left most orange LED on FlashScan's keypad is flashing - that indicates FlashScan is receiving RS232 data which means the physical connection is ok.
    Then wait for about 5-10 seconds to allow FlashScan time to record some of the RS232 data from the wide band controller.
    Then save a trace file on FlashScan, copy it to the PC using EFILive Explorer and email it to me.
    Also in the email give a brief description of what data the wide band controller was outputting at the time, i.e. Lambda values, or an error, or a status such as "warming up".
    Include a link to this thread so I know what the email is about.
    Sep 2006
    Thanks Paul ,
    Will get onto it as soon as I can .
    Kyle
    Aug 2009
    Hey guys , have we gotten anywhere with this ? ( sorry to dig out an old thread )
    Quote Originally Posted by APS Luis View Post
    Hi Luis,
    If you can do what I explained in post #5, that would help me start implementing support for that MoTeC wide band.
    I don't recall if I ever received any data after my original request, it was a long time ago :(
    Sep 2006
    Hi Luis,
    Hi gents,
    I will try to get some data to Paul this week . Would be handy to have this up and running .
    I bought a TechEdge unit so I forgot about this .....
    Kyle
    Sep 2006
    Hi Paul
    I now have 3 Motec PLM units .... if you have the time can you look at serial integration.
    The PLM manual is here - http://www.motec.com.au/plm/plmdownload/ . It should contain info you require .
    Im happy to help with testing as required .
    Kyle
  1. LC1 serial to V2
    By nonnieselman in forum FlashScan V2
    Last Post: November 12th, 2008, 02:58 PM
  2. Do I need a PID to LOG serial data?
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 15th, 2008, 11:16 PM
  3. Do I need a PID to LOG serial data?
    Last Post: May 15th, 2008, 06:39 AM
  4. WB serial to LT serial?
    Last Post: May 12th, 2008, 10:17 AM
  5. Motec PLM intallation
    By 34Koop in forum General
    Last Post: November 7th, 2005, 11:23 PM
