Results 1 to 10 of 13
Thread: Where to Buy???
    Oct 2009
    Default Where to Buy???
    I currently have $800 burning in my pocket, do I have enough to buy myself a gaget like a v-2?? I currently have a 00' procharged ws-6 that has some fueling issues and I would like to see what it's doing at wot. I hope with time and help from you guys that I can learn to tune my car. The tune it has now is an EFI Live tune so I hope to see what exactly was done to it. Any comments welcomed.
    Thanks,
    Andy
    Andy
    Welcome to the forum...
    Where are you located...?
    You will also need a wideband.
    Joe
    Nov 2006
    Ive got a RR and V1 for sale.
    LC-1 WBO2
    Oct 2009
    Andy
    Joe
    I do have a wideband on my car already I believe it's an innovate. I made bung on the lower part of my header as this is where I was told to do it. It's the wideband with the small rectangular window that shows your AFR. Do I need another kind? Can you also let me know what exactly I need since I'm a first timer. I would like to move some parameters in my tune since it's extreamly rich right now. I think my injector duty cycle was programmed to be left open to compensate for my fuel loss at WOT. As it is when I go WOT my afr goes to 9.8 or so give or take. At idle it's at 11 something I believe. I think I'm leaving alot of power on the table.
    Oct 2009
    Quote Originally Posted by mr.prick View Post
    Can you break that down for me (what exactly is that). What can you do with an rr and a v1.
    If you have an Innovate wideband, it probably is an LC-1, LM-1, or LM-2... these have serial AFR output capability...
    the EFILive FlashScan V2 has serial AFR input capability...
    i.e. FlashScan V2 can read the AFR from the LC-1/LM-1/LM-2 using a serial comms cable... you can get a serial cable from TAQuickness, or see the following links:
    V2 serial/digital wideband logging:
    showthread.php?t=8858
    showthread.php?t=8115
    showthread.php?t=10251 post #2
    V2 serial/digital AFR input (LC-1):
    showthread.php?t=7532
    showthread.php?t=8348
    showthread.php?t=9340
    Or if you get a FlashScan V1 then you would connect your Innovate wideband to V1 using an analog voltage connection (same as shown in the Innovate user manual pdf).
    Tirefire,
    If you decide on a V2, these are the resellers:
    http://www.efilive.com/index.php?opt...id=9&Itemid=91
    Quote Originally Posted by Tirefire View Post
    The RoadRunner is the PCM that lets you do real time editing/tuning while the engine is running.
    Mr.Prick (his real name) will tell you more about it.
    Nov 2006
    LC-1 WBO2
