Results 1 to 8 of 8
Thread: LC1 connection and other newb questions
    Aug 2010
    Default LC1 connection and other newb questions
    Hi there. I purchased a 2000 FRC vette last November and have added a few parts to the car. I just installed an LS6 intake manifold along with headers an X pipe and highflow cats. I have also just purchased EFI live and an Innovate LC1 (which was installed with the headers and X pipe). Do I supply an additional ground to connect the LC1 to the V2 scanner? As far as I can tell I am supposed to use the brown wire from the LC1 for wide band logging and the included adapters have a pos and neg markings for the scanners analog inputs. Also I downloaded what I am assuming is the stock calibration from the PCM, when I tried to open a tun from a 2002 Z06 that was included with the EFI software I get a message stating the tune has a differant OS and no comparison will be attempted. Do I need to flash to a differant OS? Are there tun's posted from members with similar mods and would that be the best route to begin with for a complete newb like myself? Any advice is much appreciated.
    Nov 2006
    You can only compare the same OS as the one you have.
    Do you have V1 or V2?
    V2 can be connected to Innovate stuff w/serial instead of analog.
    The brown & yellow wires go to the positive terminals of the AD inputs, the green wire goes to the negative.
    If no green wire then run a separate ground for the AD input.
    Keep it separated from the white & blue ground wires.
Name:	LC-1 hookup.jpg
    LC-1 WBO2
    Aug 2010
    I have a version 2. So do I just get a DB9 coupler and connect to the black serial input on the LC1? How do I obtain a differant OS? And is there a place to obtain tun files from members with similar mods? Oh ya one more thing. Thank you for responding and the knowledge.
    Quote Originally Posted by mr.prick View Post
    Oct 2006
    DaveL, welcome to the forum.
    Check out the Holdencrazy site for standard & modified Efilive tunes.
    The Tremor at AIR
    Nov 2006
    Quote Originally Posted by DaveL View Post
    It must be a null modem, a gender-bender will not work.
    LC-1 WBO2
    Hi Dave and welcome to the forum.
    With FlashScan V2, it is highly recommended to use serial comms digital AFR if your wideband supports this (and the LC-1 does)...
    V2 serial/digital wideband logging:
    showthread.php?t=8858
    showthread.php?t=8115
    showthread.php?t=10251 post #2
    V2 serial/digital AFR input (LC-1):
    showthread.php?t=7532
    showthread.php?t=8348
    showthread.php?t=9340 post #3
    In particular, see the last link (post #3), study the pic, and follow the link to sfcables.
    There are at least two 2002 Z06 PCM files (OS id numbers 12221588 and 12593358), see www.holdencrazy.com as 5.7ute suggested.
    The EFILive tunetool allows comparison between two files having the same OS id number.
    If you added intake, headers, catback, then you might take a read at each of these tutorials (included with the install of EFILive software):
    - Calc VE Tutorial,
    - Auto VE Tutotial,
    then implement the Calc VE tutorial, see here.
    This will get VE and MAF corrected part throttle (in closed loop), then extrapolate for WOT, then use wideband to correct WOT.
    Also, have a look thru here: Summary Notes.
  1. Help a newb!
    By The Cartel in forum Black Box Logging
    Last Post: July 30th, 2009, 02:01 PM
  2. newb needs help
    By pdasterly in forum Gen III V8 Specific
    Last Post: March 4th, 2009, 11:11 PM
  3. LC1 losing connection.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2008, 01:28 PM
  4. Two More Newb Questions Please
    By drhendrix in forum General (Petrol, Gas, Ethanol)
    Last Post: May 18th, 2004, 12:48 AM
  5. Three Newb Questions Please
    Last Post: May 13th, 2004, 02:32 AM
