Just received my V2. I installed the new 8.1 software on my notebook. How do I upgrade? Is there a doc on how to do this?
Bill
Bill
2011 Camaro 2SS/RS L99 RJT
VMax Ported RJT Throttle Body
Gorilla Wheel Lock System;
Connect both your V1 and V2 (should show as upgrade mode on the LCD) to your PC. Then go to the 'Help->Upgrade FlashScan V2' menu option in the Tune Tool.
You have the option to copy used licenses from your V1, which you'd definitely do. You also have the option to move any unused/unallocated licenses. If you plan on selling the FlashScan V1 you need to leave at least one PCM license left on the V1 as no further PCM licenses can be purchased for the device.
I'm sure I've already linked your V1/V2 in our database so ordering a PCM license will fail to process. If you did want to purchase a license(s) so you could sell the V1 (if you had planned to) I will process one more order for the V1 SN Please let the reseller know (if not fro us direct) and ask them to mention that in the order notes.
Andrew
EFILive Crew
Bill you also need to keep the latest V7.5 software installed for now. V8 pass-thru reading is in public beta now so its good to test with, but if you absolutely need to get stuff done (and edit tunes), you need V7.5.
Andrew should have you squared away with his how-to, if you plan on selling your V1 then I would suggest leaving at least 1 PCM license on it.
I have them both connected. I also upgraded the firmware and software after the install. The V2 screen does shows upgrade mode. I opened the Tune Tool. When I click on Help I get a pop up saying help is not available. I will see if I can get a screen shot of the error. I brought it to work with me.
See attached screen shot.
Thanks.
Bill
I do have the latest V7.5 on my notebook. Are you saying I should not use v8 but 7.5?
Thanks,
Bill
Bill,
You need both V7 and V8...
see posts #12 and #13: showthread.php?14351-BBL-PIDs-V2&p=128785#post128785
Also, with V2 you should now be reading the AFR from your LC-1 using serial comms (instead of analog voltage)...
V2 serial/digital wideband logging:
showthread.php?t=8858
showthread.php?t=10251 post #2
V2 serial/digital AFR input (LC-1):
showthread.php?t=8115
showthread.php?t=7532
showthread.php?t=8348
showthread.php?t=9340 post #3
Thanks Joe. My first task is getting the upgrade/help to work. Do I need to hook up V2 to the car first? If I press help or info it says not avaliable yet. Do you know what this means or why I am getting this error?
Bill
I bought the V2 for my new 2011 Camaro I just ordered. Thanks for your help.
