Page 6 of 6 FirstFirst ... 456
Results 51 to 53 of 53
Thread: Strange AFR from Serial ZT-2 -- OFF by Factor of 10!
  1. #51
    At present, TAQ is not making those cables (correct me if I'm wrong)...
    you will have to fabricate one yourself (basically, cross the signals for Tx and Rx).
  2. #52
    Nov 2014
    this thread got me really confused. i see zt-2 under supported products. i see the serial cable under spare parts. now fabricate the cable myself?
    is anybody using the zt-2 box successfully through the serial connection? (i understand the analog output would be no problem.)
  3. #53
    Quote Originally Posted by dian View Post
    Yes, the V2 supports the serial comms data stream from the ZT-2... but you have to arrange for your own serial comms cable...
    ( all the brands of wideband have unique connectors compared to each other )
    If the ZT-2 comes with a DB9-ended PC cable, then all you need is a null-modem adapter...
    see post #3 here: serial-port-cable-that-goes-to-v2
  1. PLX SM-AFR Serial upgrade
    By ntae in forum FlashScan V2 BB Logging
    Last Post: May 25th, 2017, 08:26 AM
  2. Serial AFR Reads 25.00
    By AGRO in forum FlashScan V2 BB Logging
    Last Post: April 30th, 2010, 03:30 AM
  3. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  4. Converting serial Lambda to AFR
    By mr.prick in forum FlashScan V2
    Last Post: December 31st, 2009, 03:06 PM
  5. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
Tags for this Thread
